1977 PK Economy Tiller Hardware
3 replies to this topic
#1 dirtcaptain OFFLINE
dirtcaptain
  • 7 Thanks
  • 8 posts
Posted February 13, 2015 - 01:25 PM
Hey Joe,
I recently bought a 1977 PK 2414 (ser. 42029) that came with a tiller but no mounting hardware. I haven't had much luck figuring out exactly what I need as there are so many different styles. Here are a couple of pics with the tiller lined up. I wonder if you might have what I need.
#2 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted February 13, 2015 - 01:41 PM
I can look thru my files and maybe get a parts diagram and maybe instructions, not sure. Will take me a while and be later today. Yep! some things missing. Looks like you have front started right, just need the hanger iron mostly. the rear Does go on the three point, again some missing. Seems the lower arms aren't used and the lift links go right to the tiller, yet I don't see parts on tiller to connect them too as of now.
#3 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted February 14, 2015 - 02:40 PM
I just saw you were in the Joe's file, didn't catch that at first. Finally got back here to add some scans from my book. There were a couple diff tillers shown. Think yours is going to be the Fig 4-1.2 here, you have the right mounts on frame. The Fig 4-1.3 is older style without those frame mounts. Seems you will need in back the two strap lifts, which you might make, #;s 20 and 21.  In front, much more missing, the most important parts really. Two side straps #4 slip over back bar and up to the front mount to hold it back in place. The whole rockshaft #7 is needed to mount and link the tiller to the spring assist.  Then there is the Locks that are pinned over the bar and into the mount hole above to keep in place.  The 45 spring assembly for tension. Think one could get away w/out that spring and still work, but maybe that is for belt tension now that I look and you will still need it. Here's some scans, hope they show enough.
#4 Mowerz OFFLINE
Mowerz
  • 155 Thanks
  • 176 posts
Posted February 14, 2015 - 11:29 PM
We do not have anything like this right now, sorry. :(
