What was in the cabinet i bought?
15 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,474 Thanks
  • 676 posts
Posted February 12, 2015 - 07:13 PM
Bought this cabinet and look what was inside! Havent looked threw everything. The Wisconsin rings were a bonus. Could anyone id the part numbers what they fit? The part number in the 7th picture is a briggs part number. Also the black thing in the last picture has me puzzled. Its some kind of tool but what for? Part of the writing is in german. The readable part is the brand, TREYSIT. And it also has RPM-U/min in 1000. Anyone got an idea? Its got spirometer on the gauge face.
  • Alc, MFDAC, bgkid2966 and 4 others have said thanks
#2 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted February 12, 2015 - 07:17 PM
The round black thing is a "Vibra-Tach".   Just set it against an engine cover, then turn the outer dial past what you know yo would be turning and a wire extends, then slowly turn the wire back in until it begins a wide swing.  When you get the dial adjusted for the widest swing pattern, you read the rpm's on the dial.  They actually work pretty good!  I have one in my toolbox.
  • MH81, Alc, IamSherwood and 7 others have said thanks
#3 MH81 OFFLINE
  • 29,530 Thanks
  • 29,579 posts
Posted February 12, 2015 - 07:19 PM
The round black thing is a "Vibra-Tach.
You can tell that from the last pic... :D
Looks like a great haul, nothing like a full cupboard to make you smile.
  • bgkid2966, WNYTractorTinkerer, superaben and 1 other said thanks
#4 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted February 12, 2015 - 07:22 PM
I don't know what the Wisconsin DR-15D ring set fits, but it sells for around $150!
  • superaben and Bob IN have said thanks
#5 KennyP ONLINE
  • 33,268 Thanks
  • 42,720 posts
Posted February 12, 2015 - 07:28 PM
Nice score!
  • Bob IN said thank you
#6 Bill 76 OFFLINE
Bill 76
  • 1,786 Thanks
  • 1,129 posts
Posted February 12, 2015 - 07:30 PM
That's what is --tublacain or mr pete (same guy) on utube shows ya one being used.Very nice tool.
#7 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted February 12, 2015 - 07:35 PM
It should be 4 ring sets of 4 rings per piston to fit the VG4D, a big ole V4 engine.
  • KennyP, superaben and Bob IN have said thanks
#8 Bolens 1000 ONLINE
  • 13,939 Thanks
  • 17,726 posts
Posted February 12, 2015 - 07:40 PM
:ditto: thats what they are for
The factory no longer makes this set
#9 Bob IN OFFLINE
Bob IN
  • 1,474 Thanks
  • 676 posts
Posted February 12, 2015 - 07:46 PM
They have never been opened so I am assuming there all there.
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,185 Thanks
  • 5,778 posts
Posted February 12, 2015 - 07:47 PM
We had one of those engines on a bayler. I remember it being a hand-crank nightmare to start.
#11 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted February 12, 2015 - 07:57 PM
Dad had one on his baler till we bought the Massey 175, then we went to PTO drive.  His previous baler was hand crank, but his last V4 had electric start.....HUGE improvement!
#12 NUTNDUN OFFLINE
  • 10,292 Thanks
Posted February 12, 2015 - 08:47 PM
We have one of the vibra tachs and could tell from the last two pics what that piece was. Can't help you with the others. Did you buy the cabinet without seeing what was inside or did you at least get to see first? Very cool either way.
#13 MFDAC OFFLINE
MFDAC
  • 2,687 Thanks
  • 1,370 posts
Posted February 12, 2015 - 09:00 PM
It is probably a no-brainer to everyone but the points in the 4th pic appear to be automotive for GM and some AMC V-8 engines, before 1973 or 1974ish somewhere. I can't remember exactly what year the HEI ignition was available right off hand.
DAC
#14 KC9KAS ONLINE
KC9KAS
  • 5,110 Thanks
  • 4,499 posts
Posted February 13, 2015 - 05:10 AM
The town I live in had a 4 cyl Wisconsin on a water pump.
This is what supplied the town with water back in the 40's.
#15 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 13, 2015 - 08:58 AM
Many skid loaders(from several brands) in the 25-40 hp range use the Wisconsin v4. I am not sure what the model number is on the one in Dads 610 bobcat. But know he took it out of an old hay swather to put in the Bobcat. i think he said it weighed around 400 lbs.
Edited by JD DANNELS, February 13, 2015 - 09:05 AM.
