317 hydraulic flow and pressure
5 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 12, 2015 - 03:47 PM
I'm sure that this has been asked before but I am unable to find it could anyone tell me the the gpm and psi is for the 317 hydraulic pump thank you
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted February 12, 2015 - 04:24 PM
You will be looking at about 4.5 GPM @ 700 PSI
  • ace69xxx2000 said thank you
#3 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 12, 2015 - 11:14 PM
Ok thank you
#4 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted February 13, 2015 - 08:29 AM
The specs would be in the Sundstrand 15 manual. Flow will depend on rpms. On a 317 the official JD spec high speed is 3450 rpms for the engine. I'm not sure, but the Sundstrand figures might be for hydro max. input shaft speed which is 4000 if memory serves.
#5 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 13, 2015 - 10:53 PM
Ok thank you I'm going to pick up two tomorrow I was starting to make plans for them what is the best way to load them without them running
#6 contywrkr74 OFFLINE
contywrkr74
  • 1 posts
Posted March 10, 2015 - 04:50 PM
I bought a 317 an went to drain the hydraulic oil to change it an its filled with automatic transmission fluid ..do I have to put that back in or can I change to jd hygard?
