Tiller carb help
10 replies to this topic
#1 UncleWillie OFFLINE
  • 16,262 Thanks
  • 8,976 posts
Posted February 12, 2015 - 01:23 PM
The tiller I got with Crusty has need of a carb rebuild. Problem is I can't find anything to identify it.
The tiller is model # 917251883. Engine is part number 634A714
Here is a pic of the carb.
Anyone know what rebuild kit I need. I don't want to take it apart till I have what I need for it.
#2 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted February 12, 2015 - 02:23 PM
http://pages.ebay.co...id=111386543386
http://pages.ebay.co...id=131412792276
It looks like that carb my troy bilt horse has that carb and my mighty mac chipper, horse os an 8hp brigs and stratton and the chippers a 7
  • Alc and UncleWillie have said thanks
#3 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted February 12, 2015 - 02:30 PM
Yep, looks ilke old B&S updraft. I thkn you have to remoive the main jet before you can separate the top half of the body.
#4 DougT OFFLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted February 12, 2015 - 02:45 PM
Some places you will see that listed as a large 3 bolt flo-jet and other places you will see that listed as a medium flo-jet. just make sure you get a bigger kit with a 3 bolt hole air horn gasket. That is providing i'm seeing it correctly and it only has 3 bolts instead of 4. You are supposed to take out the main jet before removing the top. There is usually a new jet in the kit. The jet has a taper on it that has to seal or fuel will leak out the choke end like a bad needle and seat.
#5 UncleWillie OFFLINE
  • 16,262 Thanks
  • 8,976 posts
Posted February 12, 2015 - 02:59 PM
Any ideas on a kit part number?
#6 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted February 12, 2015 - 03:41 PM
http://pages.ebay.co...id=141513002377
I think thats the one, partnumbers in the title
#7 UncleWillie OFFLINE
  • 16,262 Thanks
  • 8,976 posts
Posted February 12, 2015 - 04:00 PM
Thanks. For some reason your first post didn't have links when I read it on my phone.
  • dlang94 said thank you
#8 dodge trucker OFFLINE
dodge trucker
  • 2,825 Thanks
  • 3,459 posts
Posted February 12, 2015 - 05:10 PM
what are the numbers from the engine?  That will help you tell the right kit.
I have one of those carbs laying on the garage floor right now with no "rest of an 8HP Briggs" to mate it up to //but it too would certainly need a kit...
#9 UncleWillie OFFLINE
  • 16,262 Thanks
  • 8,976 posts
Posted February 12, 2015 - 05:22 PM
We looked for 20 minutes and cannot find a model number on it anywhere.
#10 Bolens 1000 OFFLINE
  • 15,433 Thanks
  • 18,286 posts
Posted February 12, 2015 - 08:04 PM
Those are the common 3 Bolt Flo Jet carbs.
I stock the kits as well as the whole carb! new :D
https://bolenspartsa...-295938-394693/
#11 chieffan OFFLINE
  • 11,380 Thanks
  • 7,121 posts
Posted February 12, 2015 - 08:49 PM
When you take the jet out and then the tube, be SURE that your screwdriver does not damage the threads while removing the tube.  Mine was damaged prior and I could not get the new tube to go all the way in.  $30 later I have the tap to clean up the threads and put in another new tube an jet.  Lesson learned.
I would suggest you take a screwdriver that has the bit to fit the lot in the tube.  The taper grind the sides from the bit down to the shaft.  this will make the bit the wides part of the screwdriver and lessen the chance of damage to the threads.   Good luck.
  • Bolens 1000, Alc and dlang94 have said thanks
