OMG, am I a redneck or what?
26 replies to this topic
#1 MH81 OFFLINE
Posted February 12, 2015 - 12:30 PM
I have been noticing that the clutch would squeal on the WH Snowblower sometimes. Hadn't had time until last nite to look at it.
Rivets been rubbing
Where they were rubbing on the steel, it case hardened a ring there. Hmm, what can I do (if I wait for a new plate, I might be waist deep )
Found a friction disc from an Allis that dad had on the shelf.
Little bigger, but it won't conflict with anything. Old one measured 92 thou, new one was 210 thick.
Now to resurface the steel... Tried several things, best bet was a good file... But it would take a week.
Ok, here's a belt, and an old beat up pulley, and slide the drill press over and put the bearing shaft in the vise... Don't laugh
It actually worked really well. Couldn't be happier. I hit it with the orbital just at the end, but I don't think it was necessary.
Then I aligned the new plate with three rivets and JB Welded the new plate on. Then I put it back on the tractor.
Next, I put the rest of the assembly together and adjusted it so it was very "in gear" with a layer of paper towel and a piece of plastic in there just in case the weld oozed.
I would like to get three newer rivets to put it on with, but I'm sure the JB will hold well.
I'll let you know if it doesn't.
  • olcowhand, DH1, Gtractor and 17 others have said thanks
#2 HANKG ONLINE
HANKG
  • 6,307 Thanks
  • 3,421 posts
Posted February 12, 2015 - 12:49 PM
Yep... rednecks can be wily ones clever repair
#3 olcowhand ONLINE
  • 41,126 Thanks
  • 31,410 posts
Posted February 12, 2015 - 12:53 PM
Yes, you ARE a redneck Alan, and a clever one too!  Worked great!
  • MH81 and JDBrian have said thanks
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted February 12, 2015 - 01:00 PM
You dun allus redneks proud!  Very klever.
  • MH81, GTTinkerer, KennyP and 4 others have said thanks
#5 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted February 12, 2015 - 01:27 PM
YUP! U dun grad-e-ated!
  • MH81, sacsr, superaben and 1 other said thanks
#6 HDWildBill OFFLINE
  • 8,975 Thanks
Posted February 12, 2015 - 02:04 PM
So when ya moving to GA?
#7 TAHOE ONLINE
TAHOE
  • 7,974 Thanks
  • 5,674 posts
Posted February 12, 2015 - 02:28 PM
Welcum to da family Brudda' !!!
#8 Lmiller3358 OFFLINE
Lmiller3358
  • 1,480 Thanks
  • 1,421 posts
Posted February 12, 2015 - 02:47 PM
What, no duct tape ?
  • MH81, grnspot110, WNYTractorTinkerer and 3 others have said thanks
#9 Sawdust ONLINE
Sawdust
  • 5,655 Thanks
  • 3,368 posts
Posted February 12, 2015 - 03:25 PM
Good job that's called gittin er dun
#10 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted February 12, 2015 - 05:55 PM
Yep using what you got to fix what you have.
#11 toppop52 ONLINE
toppop52
  • 5,253 Thanks
  • 4,757 posts
Posted February 12, 2015 - 07:38 PM
I once installed modified Corvette brake pads on a golf cart, it's what rednecks do! Good job Alan!
#12 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 12, 2015 - 08:11 PM
I did a google search for "Redneck Lathe"
Yep, you're bang on Alan. You are a redneck. :thumbs:
I've got a "Redneck" chapter in my autobiography.
Can I add you in there. :smilewink:
  • MH81, KennyP and WNYTractorTinkerer have said thanks
#13 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted February 12, 2015 - 08:24 PM
Tool box necessities, Duct Tape, Bail Wire, 3N1 oil and JB Weld.... oh and a BFH. All else is for proper repairs :bigrofl:
#14 toppop52 ONLINE
toppop52
  • 5,253 Thanks
  • 4,757 posts
Posted February 13, 2015 - 07:17 AM
All repairs are proper, if they work!
#15 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 13, 2015 - 09:11 AM
No shame in a little back yard engineering! Plan B is good, it is when you run through the whole alphabet that one needs to re-tthink the problem.
  • MH81, IamSherwood and KennyP have said thanks
