another electric PTO question
8 replies to this topic
#1 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted February 11, 2015 - 06:19 PM
When you do a repower, often the PTO end of the crank is a different diameter on the new motor than it was with the old.  These electric  PTO clutches should be pretty much the same whether they come from a Wheel Horse or an Ariens or a Grasshopper, right?
If you order "the" part number called for in your tractor manual you will get  one made for the original engine. Is there a "standard" brand on these clutches?  The tractor makers did source these from an outside supplier, right?
so if I pull an engine with say, an 1-1/4" PTO and the replacement engine has some other size can I just order a new clutch (or hub) to match the new engine's PTO diameter?
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted February 11, 2015 - 07:32 PM
Thats how I do it.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 11, 2015 - 08:44 PM
PTO clutches usually come from Warner or (if you are particularly unlucky because of price) Ogura.  The almost all interchange.
There is no reason why you can't use a different clutch to match your crankshaft.
Ben W.
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted February 11, 2015 - 09:01 PM
My kohler has one size shaft..and my replacement B&S is smaller.
#5 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted February 11, 2015 - 09:33 PM
that is easier to deal with than the other way around---replacement engine shaft bigger than original engine.
#6 Lmiller3358 ONLINE
Lmiller3358
  • 1,480 Thanks
  • 1,419 posts
Posted February 12, 2015 - 05:36 AM
Is there any way to test an electric PTO when its not on a machine, I have one that I believe is off a Bolens my Dad had and was told it was good... I'd like to sell it but don't want to send someone a piece of junk
#7 greenb69 OFFLINE
greenb69
  • 270 Thanks
  • 210 posts
Posted February 12, 2015 - 10:53 AM
Aren't the electric clutches the same thing used on car and truck air conditioners?
#8 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted February 12, 2015 - 11:26 AM
basically same idea but "the same"? no.  A car AC pump gas a smaller diameter and I have never seen a car's A/C compressor shaft protrude through the hub like these would/
#9 greenb69 OFFLINE
greenb69
  • 270 Thanks
  • 210 posts
Posted February 12, 2015 - 11:28 AM
Good to know. Just curious.
Thanks
