Loaded Tires Question
34 replies to this topic
#1 backwoods ONLINE
backwoods
  • 2,363 Thanks
  • 2,660 posts
Posted February 10, 2015 - 01:34 PM
I wasnt sure where to post this.
Im currently in the process of loading my other ag for my cub with washer fluid since the other is loaded with calcium. An i got to thinking how does everyone fill their tires an what all does everyone use or have you used in the past? My tire size is the 6-12 rear for my cub 70
Edited by backwoods, February 10, 2015 - 03:08 PM.
  • tinbender7 and Coventry Plumber have said thanks
#2 Cat385B ONLINE
    Therapy CAT
  • 12,320 Thanks
  • 9,190 posts
Posted February 10, 2015 - 01:42 PM
I used the Slime brand garden hose adapter, with 4 feet of hose, duct taped to a funnel, duct taped to a step ladder.
#3 backwoods ONLINE
backwoods
  • 2,363 Thanks
  • 2,660 posts
Posted February 10, 2015 - 01:58 PM
Cat what did you put in them? im using a windex bottle with an adapter an a chunk of rubber hose it work but its slow going
#4 Cat385B ONLINE
    Therapy CAT
  • 12,320 Thanks
  • 9,190 posts
Posted February 10, 2015 - 02:45 PM
-35 washer fluid.
#5 backwoods ONLINE
backwoods
  • 2,363 Thanks
  • 2,660 posts
Posted February 10, 2015 - 02:53 PM
ok i have -20 i have one gallon in there right now an 2 more at home that need to go in
#6 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted February 10, 2015 - 03:05 PM
its easy down here..we just use strait water with some armor all mixed in..hose off a can of fix a flat and a icemaker adapter to the water hose..
  • tinbender7 said thank you
#7 cumminsdeere87 OFFLINE
cumminsdeere87
  • 16 Thanks
  • 22 posts
Posted February 10, 2015 - 03:22 PM
I put tire on its side and break bead on that side. Put a long skinny flex funnel and just start pouring in 1 gallon at a time. Takes i think around 6-7 gallons. Then fill it with air.
  • tinbender7 and Auburn David have said thanks
#8 backwoods ONLINE
backwoods
  • 2,363 Thanks
  • 2,660 posts
Posted February 10, 2015 - 03:26 PM
the tries are to rough to break the bead an a 6-12 will take that much? or is that for a bigger tire
#9 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted February 10, 2015 - 03:29 PM
My buddy loads his that way as well..but uses play sand..I figured it would eat the rim up..but he has been doing it for years..
  • backwoods said thank you
#10 cumminsdeere87 OFFLINE
cumminsdeere87
  • 16 Thanks
  • 22 posts
Posted February 10, 2015 - 04:41 PM
You be surprised how with the right tools how easy one side is to break down. Yea 6-12. I think it was 6 gallons . Been a while haha
#11 cumminsdeere87 OFFLINE
cumminsdeere87
  • 16 Thanks
  • 22 posts
Posted February 10, 2015 - 04:43 PM
All i can say is the more weight the better and the difference with fluid and then some weights really changes how these garden tractors work
#12 KC9KAS OFFLINE
KC9KAS
  • 4,960 Thanks
  • 4,394 posts
Posted February 10, 2015 - 07:18 PM
A hand pump garden sprayer works too.
Take the wand off, remove the valve core and use a hose clamp to keep the sprayer hose on the valve stem.
Put the fluid into the sprayer and pump away.
You will have to "burp" the tire because you are pumping fluid and air into the tire.
Worked very well for me.
I did buy one of these for the next time...
Edited by KC9KAS, February 10, 2015 - 07:21 PM.
  • MH81, EricR and holdenboy1960 have said thanks
#13 EricR ONLINE
EricR
  • 438 Thanks
  • 309 posts
Posted February 10, 2015 - 07:54 PM
Here is what we used, just a one gallon pump sprayer with the wand removed and rubber line we had around the garage, we filled 2 26x12x12 tires in less than 20 min.
#14 Tomwendt ONLINE
Tomwendt
  • 122 Thanks
  • 132 posts
Posted February 10, 2015 - 08:10 PM
i used the adaptor kit with a condensation pump from a furnace.works great.
#15 MH81 ONLINE
  • 28,354 Thanks
  • 29,090 posts
Posted February 10, 2015 - 09:07 PM
Pump sprayer for any with tubes, sidewall open for the ones that don't.
We have a hose adapter and have filled bigger tractor tires with it, but hardly worth the effort to set that all up for 14 gal.
BTW, you will want the calcium tire on the left.
That's is the uphill tire (most apt to spin) when plowing and the calcium is significantly heavier than WWF.
I will never put cacl in a tire again after seeing how bad the rims get, but there are a lot out there still.
Playsand... Hmmm. Playsand and a little anti rust agent might be good and heavy.
  • Auburn David said thank you
