SSI Conversion, problems, nightmare, and revelation...
24 replies to this topic
#16 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted February 10, 2015 - 08:18 AM
I feel your pain in the no spark issue with the SSI modules/ignitions. I have a custom ignition but it can still be a pain sometimes. Glad you finally figured it out.
  • Maerskn said thank you
#17 FirefyterEmt OFFLINE
FirefyterEmt
  • 456 Thanks
  • 859 posts
Posted February 10, 2015 - 09:49 AM
The funny thing is that I am almost positive that none of the components were ever bad. My Ed Stoller conversion goes back to 2010 and has never given me a problem.... ever.
  • TAHOE said thank you
#18 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted February 10, 2015 - 09:54 AM
I can see that. I am planning to modify an SSI module myself to make one of his systems, hoping to put the whole system together for under $60
Edited by TAHOE, February 10, 2015 - 09:55 AM.
  • limebuzz said thank you
#19 HANKG OFFLINE
HANKG
  • 6962 Thanks
  • 3671 posts
Posted February 10, 2015 - 12:16 PM
Whatever made you swap the cables backwards ? just out of frustration, last resort did you know that what  happened was a possibility with the battery reverse charging ? just curious because I would have shoved it off a cliff and went on CL for a different MF
  • Alc and Bill 76 have said thanks
#20 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted February 10, 2015 - 12:19 PM
I learn something new every day.  I am glad you figured out the problem and shared it with us.   Thank you.
On a positive note, I am sure by now, you are tired of all the snow but it wont last much longer, Springtime is on the way.  :wave:
  • FirefyterEmt and Bill 76 have said thanks
#21 FirefyterEmt OFFLINE
FirefyterEmt
  • 456 Thanks
  • 859 posts
Posted February 10, 2015 - 05:28 PM
It was the very last step after re-checking wires for the hundredth time to pull out the test meter to re-test to make sure there were no broken wires and I had 12v where it was supposed to be. I always like to touch the meter to the battery before testing just so I know the meter cables are good. When I did, I just got lucky and saw it read negative! That could of been easy to miss too.... After I confirmed the meter was not messed up and the battery was charged backwards, reversing the cables was the obvious choice to see if I had spark.
The most amazing thing is I left the tail light on all night and all day.... Dang if the battery is not dead yet!!! I have not turned on the headlights too....
  • MH81, Alc and KennyP have said thanks
#22 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted February 10, 2015 - 05:37 PM
Yeah, it will be a long time past visible light before the meter will tell you it's actually at 0
Once you get it low enough, you might be able to piggyback another battery long enough to get the polarity right and get the charger going.
#23 FirefyterEmt OFFLINE
FirefyterEmt
  • 456 Thanks
  • 859 posts
Posted February 10, 2015 - 06:10 PM
Yea, that's the plan... I am pretty impressed that the tail light can last almost 24 hours and show no signs of dimming! The headlights will draw it down much faster and I will try to take it to one of the parts stores and see if they can bring her back to life.
#24 Cvans OFFLINE
  • 9378 Thanks
  • 7234 posts
Posted February 10, 2015 - 11:11 PM
Your battery maintainer must be different than mine. These say if the voltage drops below 12v it will not bring them back up. They sure do make a difference on a cold start though.
#25 pianotuner OFFLINE
pianotuner
  • 92 Thanks
  • 141 posts
Posted February 11, 2015 - 04:37 PM
DOH!!!!!!!!!!!!!!!!!!!!!
I did this on a car! and fried the computer and and so on!  Totally dead batteries will charge in reverse.  I had to cut out the aftermarket alarm system and now the door lock switch doesn't work.
Thanks for making me feel not so dumb.  If you could make that mistake I feel much better.  Of course I have 6 cars to keep charged.
