Carb Problem
2 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted February 09, 2015 - 10:35 AM
I don't think I'm getting the carb adjusted right it will start and run for a little bit and then flood out. https://www.youtube....h?v=jaz-FdeyUsY
#2 lyall ONLINE
lyall
  • 2,020 Thanks
  • 1,525 posts
Posted February 09, 2015 - 11:24 AM
first what type of gas are you using?
regular unleaded gas or the blended gas?
have you checked the needle valve?
have you set the float to Kohler specs?
using the blended gas - the alcohol is not good for the needle valve.  it soften the rubber tip on the needle valve.
the float should be set around 11/16" - see Kohler's manual.  if you do not have one you can download it from the Manual section on this site.
hope this helps you
good luck
  • bbuckler said thank you
#3 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted February 09, 2015 - 12:10 PM
It just been rebuilt a couple days ago. I alway use regular unleaded in everything
