Front counterweight opinions
30 replies to this topic
#1 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted February 08, 2015 - 04:03 PM
Just out of curiosity what is every bodies opinion on value of the infamous front counterweight?
  • CharlesDes said thank you
#2 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted February 08, 2015 - 04:06 PM
I have about 80 lbs. on the front of my FF 20 to keep it steerable when plowing hard dirt!
  • Alc and Brando have said thanks
#3 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted February 08, 2015 - 04:12 PM
  weight in general helps to a certain point, you will need ballast for doing work with the rear as much as the front.  I added a very heavy but removable front bumper to the front of allis, keep the tires down when tilling and plowing but comes rite of for snow blowing.
  • Alc, sacsr and Brando have said thanks
#4 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted February 08, 2015 - 04:36 PM
I was actually referring to the rare sears counterweight and its price value but I appreciate the responses fellas.
Edited by NCtractorman83, February 08, 2015 - 04:37 PM.
  • KennyP and sacsr have said thanks
#5 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted February 08, 2015 - 05:11 PM
One could maybe Make that weight, seems I recall a posting of fella who did that???  Just a right size channel iron for the insert and make some holes, then he used concrete in a form about like what is stock for the big part. Metal rods or ??? down from metal into the crete.  Need for it????   I have no idea, don't do  ground work. Have had Sears tractors, never had the weight.
#6 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,602 posts
Posted February 08, 2015 - 06:29 PM
Hi NCtractorman83, the only place I've seen them for sale is on E bay they start and end well beyond what I'd pay, so I built on for the Suburbans they are needed when plowing hard ground.
  • sacsr said thank you
#7 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,954 Thanks
  • 5,145 posts
Posted February 08, 2015 - 10:11 PM
They'd be handy while running the sickle mower because the front is always being pulled to the right.
Only problem is the mule drive for the sickle mower also mounts to the tractor in the same spot.  :wallbanging:
  • Lauber1 said thank you
#8 TAHOE ONLINE
TAHOE
  • 8,337 Thanks
  • 5,818 posts
Posted February 09, 2015 - 07:49 AM
I agree with MNBG they are usualy priced higher than what I would ever pay. You can check steel pricing then go to from there for retail values.
If you are handy, you can get a hold of an old mule drive and make your own, I've nenver seemed to needed it myself, but then my winch mount which weighs about 40#'s stays in mule drive most of the time anyway
#9 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted February 09, 2015 - 10:30 AM
I could use some weight up front on my GT18 and like the low profile look of keeping it close to the mule drive. But a chunk of concrete that size doesn't weigh much. I have a 2 gallon bucket full of concrete that probably only weighs about 40 pounds. I'd like to get about 40 pounds up there but not this giant bucket blob getting in the way.
#10 MH81 OFFLINE
  • 29,979 Thanks
Posted February 09, 2015 - 12:43 PM
I have taken scrap steel plates and bolted them to plow mounts. I have also seen wheel weights mounted up there on brackets.
There is a post from about 6 months ago that shows the dimensions for the OEM one. A little searching should find it, but if not... I will be back later to look
#11 IWLBCNU OFFLINE
IWLBCNU
  • 123 Thanks
  • 160 posts
Posted February 11, 2015 - 10:13 AM
I haven't paid attention online, but to me $75. Luckily, I have one and someone nicely added an extension and has a second weight added. So I guess technically, I have both the front and rear ;)
  • Brando said thank you
#12 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 309 Thanks
  • 242 posts
Posted February 11, 2015 - 11:15 AM
i made a counterweight bracket for mine. here it is on one of my 73 st10s. i also am going to adapt it to a mule drive for the suburbans
#13 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted February 11, 2015 - 11:54 AM
I currently am not using my mule drive for anything and the tractor is just a puller. I'd like to pour concrete into a metal frame and secure it inside the mule drive area and secure it somehow. I should be able to pour enough concrete to get 30 to 40 pounds.
#14 MH81 OFFLINE
  • 29,979 Thanks
Posted February 11, 2015 - 12:20 PM
Check this thread
http://gardentractor...ht/#entry427619
  • KennyP, Brando and Tinker000 have said thanks
#15 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted February 11, 2015 - 03:38 PM
Wonder what that would weight in lead?
