By end of week I should be in the 1450 club.
60 replies to this topic
#31 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted February 15, 2015 - 05:37 PM
I don't know of any wiring diagram for these. Some one else may have something. I didn't get pics when I pulled the flywheel to check the stator. At the time, I didn't realize there was no paperwork on these systems. The trigger module is just under the flywheel shroud.
So thats where the tin can cut in? I need to take off the shroud anyways.
#32 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted February 15, 2015 - 05:59 PM
You'll see the trigger right there once the shroud is off. I'm not saying that is your problem, but worth looking into. Helps you understand the system too. You probably have a 10 amp stator in there too.
#33 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted February 16, 2015 - 09:18 AM
This morning I went out to the 1450 to try and get it running and I noticed that the ignition coil wire was off. Nope! Broke off the whole dang tab! :mad2: Looks like now I'm going to convert to points unless anyone has a good way to fix it.
#34 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted February 16, 2015 - 09:53 AM
Now you know where the issue was. Is it the coil wire broken off, or the wire from the trigger?
#35 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted February 16, 2015 - 10:04 AM
the wire that goes to the coil the tab on the ignition coil is broke off. This problem wasnt there when I got it but I figure if I leaned over I might have caught it and bent it
#36 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted February 16, 2015 - 10:27 AM
Know anyone that does elecroinics work? They might be able to fix it.
#37 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted February 16, 2015 - 10:39 AM
I was thinking of soldering it a little bit. Just have to do a little at a time so I dont over heat it.
#38 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted February 16, 2015 - 10:49 AM
Might be worth the try!
#39 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted February 17, 2015 - 01:20 PM
Well this morning I had spark. I was so excited so I sprayed in some starting fluid and nothing happened. Then it popped once and that was it. I took off the head and the exhaust valve is stuck open. Oh yay me :wallbanging:
#40 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted February 17, 2015 - 01:22 PM
Put some lube on the stem and see if you can tap it down a little!
#41 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted February 17, 2015 - 02:29 PM
Ok right now it's soaking with some MM oil on it. I noticed that the side of the piston that faces the valves looks a little worn down on the side (I can see the top ring) so I figure I might as well rebuild it. Put new piston, rod, and valve train in it
#42 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted February 17, 2015 - 05:02 PM
If the piston is that bad, you may as well.
#43 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted February 17, 2015 - 10:07 PM
Is it common for these K321 to wear down pistons on the side closest to the valves? This is the third engine I've gotten like this. Thanks
#44 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted February 18, 2015 - 05:31 AM
That I haven't a clue on. I only have one and it looked pretty good when I did the head gasket.
#45 Sprint 6 ONLINE
Sprint 6
  • 227 Thanks
  • 293 posts
Posted February 18, 2015 - 08:34 AM
All engines wear the piston and bore more on the thrust side of the cylinder.  The thrust side is always the side of the bore that is counter to engine rotation, thus the valve side on a Kohler.  This is phenomenon is common to all engines, whether single cylinder, multi-cylinder, or any number V configuration.
  • KennyP and TomLGT195 have said thanks
