Cracked Axle Tube on AC 917Hydro. Help!
13 replies to this topic
#1 Hartski OFFLINE
Hartski
  • 2 posts
Posted February 08, 2015 - 10:03 AM
So i finally got Dad's 1978 AC 917 hydro and not 30 minutes after getting it home, the axle tube cracked and ruined the axle seal. I was able to get new seals, but so far, I've been unable to locate a replacement axle tube. Does anyone out there know where i could find one?
#2 boyscout862 ONLINE
  • 12,853 Thanks
  • 9,172 posts
Posted February 08, 2015 - 01:12 PM
Welcome to GTT. Check with our sponsors for parts. Good Luck, Rick
#3 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 08, 2015 - 01:20 PM
welcome to GTT.
That's really unfortunate, about the tube. What
caused that to happen?
You could also try running a "Wanted" ad here in the classifieds.
#4 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted February 08, 2015 - 09:05 PM
I'm thinking a tube will probably run more than an entire rear end from a parts donor.  Plenty out there.
#5 KennyP ONLINE
  • 38,360 Thanks
  • 45,927 posts
Posted February 09, 2015 - 06:08 AM
What brand axle is in this tractor?
#6 Hartski OFFLINE
Hartski
  • 2 posts
Posted February 09, 2015 - 10:00 AM
Everything on the tractor is stock, except for the engine.
#7 skifoof OFFLINE
skifoof
  • 54 Thanks
  • 86 posts
Posted February 15, 2015 - 10:37 AM
I agree with talented,theres tons of donor tractors everywhere,i bought several tractors whole free to $100 just so I have extra parts,i probably have about 45 allis tractors
#8 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted February 21, 2015 - 09:39 PM
Welcome to GTTalk!
#9 MH81 OFFLINE
Posted February 22, 2015 - 12:30 AM
Can one of you Allis guys give a rough idea as to what models might have usable parts for him?
#10 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted May 04, 2016 - 12:54 AM
I'm guessing but since no one else gave it a shot...I think any of the 70xx or 71xx series Simplicity hydros,or the 7xx and 9xx Allis hydros would work for a complete rear swap as long as it has a Sunstrand pump. As for the axle tube I think one from any of these or the gear drive models would work. And a few other models might work too.
Edited by rustyoldjunk, May 04, 2016 - 12:54 AM.
#11 John Arsenault ONLINE
John Arsenault
  • 2,584 Thanks
  • 1,213 posts
Posted May 04, 2016 - 08:04 AM
I have a complete trans out of a 3415H ....I looked it up says its a vickers
http://gardentractor...lete-or-parts/
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 04, 2016 - 08:09 AM
:welcometogttalk: :camera:
#13 ACmowerguy OFFLINE
ACmowerguy
  • 419 Thanks
  • 368 posts
Posted May 04, 2016 - 07:37 PM
This post originated over a year ago, but since its back up to the top I will add this, I believe any of the tubes from the large-frame hydrostatic drive tractors will interchange regardless of whether they are on a Vickers or sunstrand machine. The gear drives use a totally different tube. New tubes are around $200 from Simplicity. What I don't like about used transmissions, differentials, or gearboxes, is often the wear and problems are not readily evident as they are often covered with layers of accumulated and hardened grease. You would want to clean the axle of grease and sand the paint off it with some emery paper and look very closely for cracks, especially near the keyways.
Edited by ACmowerguy, May 04, 2016 - 07:42 PM.
  • rustyoldjunk said thank you
#14 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted May 07, 2016 - 09:56 PM
I knew it was an old post when I replied to it but the poster had been left hanging so I thought I would at least give it a shot. Besides we all research old threads for info,so the more info in an old thread,the better.
Edited by rustyoldjunk, May 07, 2016 - 09:57 PM.
