Valve spring removal tool
16 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,316 Thanks
  • 4,368 posts
Posted February 08, 2015 - 08:53 AM
What tool do you use for removing valve springs and valves on the Kohler K series and small Briggs flathead engines?  I am going a bit deeper into my K301 (building a Kirkengines.com KillerKolher) for my 312 and am looking for the right tool for the job.
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 08, 2015 - 08:59 AM
I use this style for every engine
They also have some cool magnetic tools you can use to install the keepers but havent tried them yet.
  • KennyP and johndeereelfman have said thanks
#3 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted February 08, 2015 - 09:08 AM
That is the same valve spring compressor tool we use also. The hardest part is getting it under the top of the spring most of the time but it works once you get the spring in there just right. The keepers sometimes go in nice and smooth and other times they can make you say a few words I don't dare to repeat LOL.
I gotta say though the little pin keeps on the Briggs we just worked on were the easiest to deal with.
#4 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 08, 2015 - 09:14 AM
For easy keeper installation I always put a dab of grease on them so they stick to the valve
  • boyscout862 and alec have said thanks
#5 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted February 08, 2015 - 09:17 AM
I will have to try the grease method. I always just use fresh 30wt oil to help get the keepers to stay in place. Usually works but there is always the times where I get the first half on for a Kohler and when I go to put the second half on I knock the first half off.
  • boyscout862 and propane1 have said thanks
#6 KC9KAS ONLINE
KC9KAS
  • 5,390 Thanks
  • 4,693 posts
Posted February 08, 2015 - 10:06 AM
The grease trick will work better.
#7 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 08, 2015 - 11:53 AM
I use an automotive C style but it can be a pain.I use the grease trick every time and it works wounders
#8 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted February 08, 2015 - 01:10 PM
I've used the B&S type spring compressor but it isn't easy with the Kohlers. I splurged and bought one of the "C" clamp type for the K301 that I'm working on. I haven't tried it yet. The mangetic keeper tool works some times when there is enough room. I've thought about making a jig to hold the engine upside down for ease of assembly. Good Luck, Rick
#9 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted February 08, 2015 - 06:03 PM
I made a "C" clamp type valve spring removal tool when I rebuilt my K341 and it worked well.  I also used the small dab of grease to hold the keepers and had no problems.
#10 IHCubGuy ONLINE
IHCubGuy
  • 1,537 Thanks
  • 1,602 posts
Posted February 08, 2015 - 07:13 PM
I have had this one from sears for years.  I bought it for use on the big farm tractors but it works on the small engines as well.
http://www.craftsman...pid=00947627000
#11 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 08, 2015 - 07:14 PM
Pictures?
#12 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted February 08, 2015 - 09:05 PM
Bmerf, I'll try to get a couple of pictures and post them tomorrow.
  • Bmerf said thank you
#13 Trav1s ONLINE
Trav1s
  • 3,316 Thanks
  • 4,368 posts
Posted February 09, 2015 - 10:26 AM
Thanks all!  I have been debating a stop at Harbor Freight to see what they have.  Your pics have been very helpful.
#14 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted February 09, 2015 - 12:52 PM
Here's some pictures of my homemade valve spring compressor.  I also drew up a sketch with measurements that might be a little help.  Forgot to include the measurement from the back side of the clamp to the end of the slot on the bottom end.  That distance is approximately 2".
  • KennyP, Trav1s, HDWildBill and 1 other said thanks
#15 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted February 09, 2015 - 01:15 PM
Neat tool!
