Great ! Just what I needed...
13 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted February 07, 2015 - 08:53 PM
Now the C81 is leaking antifreeze.
  • Gtractor, MH81, hamman and 5 others have said thanks
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 07, 2015 - 09:02 PM
ok?? right.......... :beer: ?
  • rustyoldjunk and Nxt2doc have said thanks
#3 Cvans ONLINE
  • 6,649 Thanks
  • 6,132 posts
Posted February 07, 2015 - 09:30 PM
When mine does that it's usually the hose clamp on the lower radiator hose.   :smilewink:
  • rustyoldjunk, tinbender7 and Nxt2doc have said thanks
#4 MH81 OFFLINE
Posted February 07, 2015 - 10:02 PM
Make sure the 710 cap is tight and the winter air was changed in the tires. Little known fact that these simple things can cause this problem
  • rustyoldjunk, tinbender7, Cvans and 2 others have said thanks
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,335 Thanks
  • 4,956 posts
Posted February 07, 2015 - 10:37 PM
Its probably the heater core.  Pull the glovebox out and look in there.
  • rustyoldjunk, Cvans and Nxt2doc have said thanks
#6 glgrumpy OFFLINE
  • 8,616 Thanks
  • 7,923 posts
Posted February 07, 2015 - 11:05 PM
Spilled your Mixed drink trying to set it on tire and not the nice painted hood, right?  OH, this not one of those "Wazzat"?  posts?
  • rustyoldjunk, MH81, Cvans and 1 other said thanks
#7 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted February 07, 2015 - 11:18 PM
Had that problem once. Switch to Volkswagen Beetle antifreeze and it fixed the problem.
  • rustyoldjunk, Cvans and Bill 76 have said thanks
#8 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted February 07, 2015 - 11:32 PM
Those K's are known to leak from the freeze plug (casting plug)  behind the flywheel. Good luck!! I hope it is an easy fix. :poke: :rolling:
If ya need help, I'll be in after I finish rotating my spark plugs on my truck. :beer: :D
  • rustyoldjunk, Cvans, Bill 76 and 1 other said thanks
#9 Bill 76 ONLINE
Bill 76
  • 1,938 Thanks
  • 1,192 posts
Posted February 08, 2015 - 12:28 AM
 If you don't keep the chrome muffler bearings polished it can lead to leaking by the canution valve.
#10 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted February 08, 2015 - 10:38 AM
Maybe your intake gasket sprung a leak.I hope it's not cracked! :D
  • rustyoldjunk, Bill 76 and Nxt2doc have said thanks
#11 Texas Deere and Horse ONLINE
  • 14,814 Thanks
  • 15,501 posts
Posted February 08, 2015 - 01:30 PM
If the muffler belt is slipping, it can cause the engine to overheat and cause the water injection pump to fail and leak. Boy, I hope it's not that because the whole engine could be ruined !!
#12 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted February 10, 2015 - 05:37 PM
Looks like the bull wheel jumper the heifer shaft and threw the finagain pin
#13 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted February 11, 2015 - 12:17 AM
Thanks to everyone for the helpful suggestions ( some after hours spent researching them,I still can't define,but thats another post),anyway,after repacking the front wheel bearings,adjusting the PTO clutch,tightening the engine mounts,and re torquing the head bolts,and seat mount, my youngest daughter,my oldest grandson,and I took the tractor out and ran it for a few hours and no leaks ! Even after sitting overnight still no leaks ! Thanks again for all the help !
Edited by rustyoldjunk, February 11, 2015 - 12:18 AM.
  • KennyP, Cvans and Bill 76 have said thanks
#14 UncleWillie ONLINE
  • 15,676 Thanks
  • 8,763 posts
Posted February 11, 2015 - 10:18 AM
Sometimes the aircooled antifreeze can be impossible to stop from seeping out. Try putting a table spoon of black pepper in it to slow the seepage.
  • rustyoldjunk said thank you
