Kohler KT vs Magnum twins?
9 replies to this topic
#1 dodge trucker ONLINE
dodge trucker
  • 1,885 Thanks
  • 2,504 posts
Posted February 07, 2015 - 07:37 PM
nevermind, found the thread I "thought" I'd started on here once before.... strangely didn't show up when I searched for it earlier...
Edited by dodge trucker, February 07, 2015 - 07:45 PM.
#2 glgrumpy OFFLINE
  • 8,149 Thanks
  • 7,584 posts
Posted February 07, 2015 - 08:40 PM
KT's are SO junky that the sellers at the Portland swap meets don't even bother to load them on their sale trailers anymore and won't sell the parts. Most have Rods broken and big holes in cases. Not parts from Kohler on them anymore, and even used pistons and rods IF any around are hard to locate. Magnums are more modern and much better rig and workable.
  • Canawler and Cvans have said thanks
#3 Utah Smitty OFFLINE
Utah Smitty
  • 1,682 Thanks
  • 1,773 posts
Posted February 07, 2015 - 11:12 PM
True enough on the KTs... I have one with daylight showing in the crankcase myself.
One interesting note--the Kohler Magnum 20 has the same bore and stroke as the Kohler KT19-- some of the sheet metal is the same part number as well...
I've suspected for a while that Kohler based the Magnum twins on the KT series... without the reliability problems. This SEEMS to support that theory...
Smitty
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted February 07, 2015 - 11:36 PM
KT had the oil slinger for the bottom end and had trouble on hills right?..I hope this isn't true of my Magnum 18?
#5 Utah Smitty OFFLINE
Utah Smitty
  • 1,682 Thanks
  • 1,773 posts
Posted February 08, 2015 - 12:07 AM
I own a Magnum 18 and haven't had any problem with that... 'course it has a pressurized lube system, and oil filter, too.
Evenso, I'm not aware of that problem with any of the Magnums... I'm sure if someone else has, they'll let us know...
Smitty
#6 Bill 76 OFFLINE
Bill 76
  • 1,832 Thanks
  • 1,147 posts
Posted February 08, 2015 - 12:35 AM
I always thought that hole was an inspection hole so you could watch things moving.
  • Auburn David said thank you
#7 Utah Smitty OFFLINE
Utah Smitty
  • 1,682 Thanks
  • 1,773 posts
Posted February 10, 2015 - 10:31 PM
Only problem is... when you let the light in, you let the oil out!!  LOL!!
Smitty
  • Bill 76 and Auburn David have said thanks
#8 dodge trucker ONLINE
dodge trucker
  • 1,885 Thanks
  • 2,504 posts
Posted February 10, 2015 - 11:03 PM
Smitty
put a plexiglass  sight window on it
#9 bgkid2966 OFFLINE
bgkid2966
  • 1,409 Thanks
  • 1,330 posts
Posted February 11, 2015 - 08:35 AM
What is oil? Do we need it inside? Most of mine seems to be on the outside! It is neat to be able to see everything moving in there! :wave:  :wave:
Geno
#10 Utah Smitty OFFLINE
Utah Smitty
  • 1,682 Thanks
  • 1,773 posts
Posted February 11, 2015 - 11:08 AM
No, you don't need it inside--as long as you want a static display. ,o)
Smitty
