Possibly going to look at a power king with a fel
7 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 07, 2015 - 03:10 PM
Is there anything I should check for guys says runs great it has a fel on it that doesn't look factory to me from the pictures I have seen he also said its a 14hp but I'm not sure if it's a 24 or 16 this would be my first power king any advice would be appreciated
  • Bill 76 said thank you
#2 Bill 76 ONLINE
Bill 76
  • 1,748 Thanks
  • 1,111 posts
Posted February 07, 2015 - 04:34 PM
I do belive a 24 would have 24inch rear wheels and a 16 would have 16 inch rear wheels
  • ace69xxx2000 said thank you
#3 boyscout862 ONLINE
  • 10,486 Thanks
  • 7,914 posts
Posted February 07, 2015 - 05:58 PM
Download a couple of the manuals from our Manuals Section and read them. Look carefully at the tractor when you get there. Look for cracks, leaks, and that everything is straight. The FEL may be bent or the front axle may be. Look at the pins of the FEL for wear. Loosness of parts and joints can indicate age and possible problems. Be very carefull unless it is very cheap. I've spent alot of time making parts and welding up loaders. I enjoy it but you may not. Good Luck, Rick
Edited by boyscout862, February 07, 2015 - 05:59 PM.
  • ace69xxx2000 and sacsr have said thanks
#4 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 07, 2015 - 07:32 PM
Ok thank you I'm not sure what cheap would be for one of these but he wants 800
#5 Bill 76 ONLINE
Bill 76
  • 1,748 Thanks
  • 1,111 posts
Posted February 07, 2015 - 08:14 PM
I just sold a  1971  1614 dual tranny  without a loader for 800---Hour after it went on craigslist I got about 8 calls,guy bought it that night.-I should have asked more.
It was a good running tractor with just a mowing deck , with no battery--he didn't even want to here it run.
#6 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 07, 2015 - 08:58 PM
Ok I guess 800 doesn't seem to bad just a lot toe the most I have ever spent on a tractor is 300 and that was a jd210
#7 glgrumpy ONLINE
  • 7,164 Thanks
  • 6,883 posts
Posted February 07, 2015 - 09:12 PM
That is very good price for one with loader! There is an older early loader that kind of HANGS off the frame with long full -length running frame and big round oil tank that is not as nice as the later loaders with center frame mount and tanks in uprights. The 16" wheels are better for a loader, less tip over chance than the 24", but both will work if you are careful not to over-do them. Kind of hard to judge w/out pictures, but sounds like you should be OK. Find serial # on the dash or grill to find out year of tractor and post back here. Newer tractor is best buy, but many older rigs are doing great with good care.
#8 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 08, 2015 - 05:05 PM
Thanks guys for your help someone beet me to it sad thing was it had been posted since September and just now sold
