Tiller
12 replies to this topic
#1 Simpleton OFFLINE
Simpleton
  • 120 Thanks
  • 78 posts
Posted February 07, 2015 - 09:47 AM
Will a tiller off a 3012 fit a 7114?
#2 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted February 07, 2015 - 12:08 PM
They take different PTO setups for sure
  • Simpleton said thank you
#3 nlpoole OFFLINE
nlpoole
  • 6 Thanks
  • 12 posts
Posted February 25, 2015 - 10:00 AM
So no it would not fit
#4 Talntedmrgreen ONLINE
  • 3,293 Thanks
  • 2,320 posts
Posted February 26, 2015 - 07:06 PM
Depends on tiller model...a 36" is a match made in Port Washington. Only difference for your purposes will be belt length.
Is the 7114 a hydro?
#5 Simpleton OFFLINE
Simpleton
  • 120 Thanks
  • 78 posts
Posted February 26, 2015 - 10:20 PM
Yes, 7114 is hydro.
Other issue is the 7114 doesn't have a rear lift. I would need to find one for it.
Could I make the lift on my 3012 work on the 7114?
Edited by Simpleton, February 26, 2015 - 10:23 PM.
#6 Talntedmrgreen ONLINE
  • 3,293 Thanks
  • 2,320 posts
Posted March 01, 2015 - 11:07 PM
Yes....the newer machine will require a cable vs rod for lifting, and to do so properly, there is a small pulley to be added beneath the tractor.  There is also a stepped-collar bushing on the LH side of your lift bracket, where it meets the drawbar assembly.  The early machines had 3/4" holes on either side of the drawbar for the lift bracket to sit in.  The later models went to a larger dia hole on the LH side, thus the need for the collar that takes up that extra space.
  • MH81, alec and Simpleton have said thanks
#7 Simpleton OFFLINE
Simpleton
  • 120 Thanks
  • 78 posts
Posted April 19, 2015 - 08:01 PM
Well, I finally had some time to look into this. The tiller wasn't set up correctly on the 3012. The PO tried to move the pto pully on the bgb out far enough to run the belt straight from the tiller to the bgb pully. Didn't work. The 3012 needs too much work to get it going for this spring. The tiller looks to be the type that should work on the 7114. I cant find the id plate on the tiller, due to someone doing a crappy repaint.
I have the lift almost complete, just need the cable and little pully to go under the tractor. Any one have any idea what length the cable should be?
The big issue is the missing PTO drive group needed for the drive connection.
#8 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 19, 2015 - 09:02 PM
http://www.simplicit...5_AT_SMA_LO.pdf  look at page 58 . also click on my name , look at my content . there are several posts about what you are going through . I just made the cable and bought a pulley from the farm store . they have cable and fittings that look like little squares with holes in it . you cant use the multiple u clamps . I inserted the cable in the holes then sqished it like hell in the vice then center punched it six times on each side (three on each cable ) . I cant find the measurement that I just wrote down but I got extra and free handed it anyway . ( it was like 48 inches ) one guy made his short so he could ad links and change the length .you will need something to keep the cable round at the curve I used the teardrop shaped ones some people use a small pulley ( about the size of a 9/16 nut ) cant find the picture ( sorry man ) hope this helps .
#9 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 19, 2015 - 09:10 PM
Give us some photos. It is much too hard to try to describe the differences. A couple of photos of tiller and pulley array would tell us what you need to make it work.
Edited by skunkhome, April 19, 2015 - 09:11 PM.
  • alec and Simpleton have said thanks
#10 Simpleton OFFLINE
Simpleton
  • 120 Thanks
  • 78 posts
Posted April 20, 2015 - 07:50 AM
Here is what I have.
#11 Simpleton OFFLINE
Simpleton
  • 120 Thanks
  • 78 posts
Posted April 20, 2015 - 08:26 AM
And this is what I want to put it on.
IMG_20150420_085357307.jpg IMG_20150420_085405005_HDR.jpg IMG_20150420_085413738_HDR.jpg IMG_20150420_085431258_HDR.jpg
#12 ACmowerguy OFFLINE
ACmowerguy
  • 459 Thanks
  • 387 posts
Posted April 20, 2015 - 08:52 PM
While it does have the "squared hood" That is only a 32" tiller. I'm afraid its not a mate to your 7114.
#13 Simpleton OFFLINE
Simpleton
  • 120 Thanks
  • 78 posts
Posted April 21, 2015 - 05:31 AM
Well, that's not what I was hoping to hear, but thanks for the reply.
I did find, on ebay, the drive pulleys needed for the 3012. The starting bid is $122 :wallbanging:
