Cub Cadet 123 Front Wheel Bearings
2 replies to this topic
#1 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted February 06, 2015 - 10:30 AM
I thought that the front wheel ball bearings on my CC 123 needed to be replaced. When I took the first wheel off, the outside ball bearing fell out. The bore has been wobbled out. The new bearing is loose in the bore as well. And, it's the same way on the other side, except that the old bearing had to be driven out. Is there any way to fix this, or are my rims no good? Thanks.
Edited by Gabriel, February 06, 2015 - 10:33 AM.
#2 EricR ONLINE
EricR
  • 709 Thanks
  • 427 posts
Posted February 08, 2015 - 04:31 PM
Gabriel one way to fix this problem is take a punch or chisel and go around the outside of the rim and just bend it in a little. I have done this with and without the bearing on the wheel!
  • Gabriel said thank you
#3 nlpoole OFFLINE
nlpoole
  • 6 Thanks
  • 12 posts
Posted February 25, 2015 - 11:37 AM
Agreed with eric
  • EricR and Gabriel have said thanks
