Restoration questions
21 replies to this topic
#16 Simpleton OFFLINE
Simpleton
  • 117 Thanks
  • 77 posts
Posted February 05, 2015 - 11:48 PM
Depending on the definition of burned up, if all it needs is a good rebuild, you can get a gasket set, piston, rings, and a new rod for $85 + shipping.  If you need to turn the crank to .020 under, that rod is available for $10 extra.  A .010 over piston is available, too, for no price difference off the original.
Ben W.
I will need to determine whether I need stock parts or oversize and get back to you Ben. Thanks for your help.
#17 Simpleton OFFLINE
Simpleton
  • 117 Thanks
  • 77 posts
Posted February 06, 2015 - 10:05 AM
A couple engine part photos.
#18 Simpleton OFFLINE
Simpleton
  • 117 Thanks
  • 77 posts
Posted February 06, 2015 - 10:10 AM
There doesn't seem to be any deep gouges in the cylinder wall.
The crank looks pretty bad but I haven't mic-ed it.
I'm assuming the next step is to have a machine shop mill the crank and cylinder?
By the way, I did not tear the engine apart. The PO had it in bags and boxes.
Edited by Simpleton, February 06, 2015 - 01:33 PM.
#19 Sawdust OFFLINE
Sawdust
  • 6,050 Thanks
  • 3,502 posts
Posted February 06, 2015 - 10:27 AM
I need to take back my advice on what to do with your rust. After seeing your pics I agree with VintageIronCollector leave as is. Just fix the engine & go. Looks nice not too many around with that much paint.
  • ACB112Guy and Simpleton have said thanks
#20 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted February 06, 2015 - 11:29 PM
The crank looks to have more aluminum deposits than anything else.  I bet they will come off with a careful application of muriatic acid.  VERY careful!
Ben W.
  • Simpleton said thank you
#21 Simpleton OFFLINE
Simpleton
  • 117 Thanks
  • 77 posts
Posted February 07, 2015 - 08:38 AM
Ben W.
Thanks Ben, I'll give that a try.
#22 Simpleton OFFLINE
Simpleton
  • 117 Thanks
  • 77 posts
Posted February 28, 2015 - 04:27 PM
Got too many irons in the fire. This tractor stuff is addicting. Getting as bad as my Traditional Archery addiction :loosing_it:
Anyway, the crank journal mics ok as is. Just needs cleaned up. The acid took the aluminum off.
The cylinder is a bit out-of-round but I think it will hone out ok to .20 over.
I need to finish the clutch on the Bolens, then I'll get at this. I've already got most of the engine parts cleaned up.
