sad day the beast is out of commission for a while
38 replies to this topic
#1 Beast Jacobson OFFLINE
Beast Jacobson
  • 12 Thanks
  • 22 posts
Posted February 04, 2015 - 03:06 PM
Coupling gave way. Took out the lift cylinder and the valve line. Looks like the drive shafts bent. Plastic fins on the command half gone, but still runs.
going to be a while before I can fix it. Will it be better  to drain the hydro  fluid or tape it up till I can get to it?
  • MH81, Alc, Texas Deere and Horse and 2 others have said thanks
  • 14,889 Thanks
  • 15,514 posts
Posted February 04, 2015 - 03:17 PM
Looks like a bad wreck for sure, hope your able to get it fixed up right.
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted February 04, 2015 - 03:31 PM
Just tape it off, should be fine.
#4 glgrumpy OFFLINE
  • 8,815 Thanks
  • 8,014 posts
Posted February 04, 2015 - 03:59 PM
Wow, really Grenaded there!  Something else lock up to do that?  Does the rear end still turn OK?  Maybe needed some better grade bolts at the joints?  With some lock type nuts or washers?
#5 Beast Jacobson OFFLINE
Beast Jacobson
  • 12 Thanks
  • 22 posts
Posted February 04, 2015 - 04:19 PM
Drive shaft still turns, the engine isn't  sitting  perfectly straight. Maybe that's why.
#6 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted February 04, 2015 - 04:24 PM
How did that sound when it happened. Hate to hear of such a problem this time of the year. I agree tape it up good to keep the dust & critters out until later.
#7 Beast Jacobson OFFLINE
Beast Jacobson
  • 12 Thanks
  • 22 posts
Posted February 04, 2015 - 04:42 PM
Loud boom and plastic everywhere  from the fan fins. Engines out i'm guessing  these brackets aren't  original.
#8 UncleWillie ONLINE
  • 16,254 Thanks
  • 8,971 posts
Posted February 04, 2015 - 04:48 PM
Ouch. Time (and money) heals all wounds.
#9 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted February 04, 2015 - 05:01 PM
How long did you own this before this failure? I would be curious to see the failure analysis. Did you run over something and it caught the driveshaft?
I would like to understand what caused that.
#10 KennyP ONLINE
  • 40,912 Thanks
  • 47,110 posts
Posted February 04, 2015 - 05:27 PM
I'm guessing you had a repower in there! Cause that is not a normal engine mount and the original ones look in sad shape!
#11 Beast Jacobson OFFLINE
Beast Jacobson
  • 12 Thanks
  • 22 posts
Posted February 04, 2015 - 06:31 PM
I had just put new gas and the engine was surging, I blew out the fuel line and was alternating between full throttle and idle when boom. Got it all took apart ( it's  amazing how easy it is on this tractor). Looks  like the engine  only needs the fan blades and a couple of frayed  wires replaced. The tractors going to need a new drive shaft, coupler, adapter and whatever that material is between the drive shaft and coupler, line from valve to filter and line from valve to lift cylinder.
#12 Justin2655 OFFLINE
Justin2655
  • 211 Thanks
  • 151 posts
Posted February 04, 2015 - 07:24 PM
That deffantly sounds like a not a good day. Hope things get back together for you
#13 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted February 04, 2015 - 07:33 PM
Sad news indeed!
What kind of engine are You running in it?
It originally would have had a Kohler single on isolation rubber mounts.
If someone mounted the engine solid in there maybe it wasn't well aligned?
Joe
#14 propane1 ONLINE
propane1
  • 9,457 Thanks
  • 4,391 posts
Posted February 04, 2015 - 08:58 PM
Sorry to hear your troubles . Hope it repairs good. And I thought my troubles with two ford blowers is bad. Noel
#15 Beast Jacobson OFFLINE
Beast Jacobson
  • 12 Thanks
  • 22 posts
Posted February 04, 2015 - 09:09 PM
It was a kohler command ch13 out of a cub it was just slightly out of line. I got it the middle of October. It's been a beast so far moved lots of stone, and snow.
  • Rock farmer said thank you
