Anyone know where i can find some of these? Otherwise i will just buy some brass or sintered something and make some.
Help finding bushing for GT/LGT Blower
#1
OFFLINE
Posted February 03, 2015 - 09:35 AM
#2
OFFLINE
Posted February 03, 2015 - 10:11 AM
Got a size or part number?
I can get a bushing thats like that but you'll have to drill the hole.
- Alc said thank you
#3
OFFLINE
#4
OFFLINE
Posted February 03, 2015 - 12:21 PM
Found some. Thanks for the link JMS180 - it led me to another site where i found some. might not be quite a press fit but i'll find something to hold it
#5
OFFLINE
Posted February 03, 2015 - 04:48 PM
Great glad to help you
#6
OFFLINE
Posted February 03, 2015 - 04:49 PM
you could also check msc.com, they are where I got all the bushings and shims for my b-10 restoration.
#7
OFFLINE
Posted February 04, 2015 - 02:48 AM
Baum Hydraulics has about any kind of bushing or bearing you would ever need. In Omaha, NE.
#8
OFFLINE
Posted February 10, 2015 - 09:04 PM
Did the bushing you got ever work out? I actually have the same problem with the same snowblower I have. Have any tips on replacing these?
#9
OFFLINE
Posted February 11, 2015 - 07:04 PM
i ordered some.. it seems the shaft on my spare snowblower is different size than on my tractor now. The "outside" end of the shaft is different size anyways. I think i will just need to ream the bushings i bought or turn on a lathe.
#10
OFFLINE
Posted February 17, 2015 - 10:52 PM
Bearing brass is EXPENSIVE - a 1 inch thick bar 12 inches long was $35 or so, but you can make whatever you need as long as the od fits. And probably cheaper in the long run than buying premade ones. a foot goes a long way....
Been a year or so ago, but my lgt165 rebuild with some pictures of the bearing making are on here if you are interested.
- FixItCharlie and FilledTires have said thanks
#11
OFFLINE
Posted February 18, 2015 - 07:00 AM
IF YOU HAVE ACCESS TO A LATHE - make your own. I ran into that problem when refurbing my LGT165. There were lots of bushings in the mower carriage that were worn, but the shafts were worn as well. I bought a 12 inch bar of bearing brass and just made what I needed to fit each spot. And I still have plenty left for future use.
I would be interested in seeing the pictures. Do you have a link leading to the pictures?
#12
OFFLINE
Posted February 18, 2015 - 08:46 AM
http://gardentractor...tures/?p=323529
If that didn't work it was originally started March 6, 2013, here in the Ford group and titled "Ford LGT165 Closed Side Refurbish Pictures". Post 20 is the one with the bearing pictures....
- KennyP, FixItCharlie and FilledTires have said thanks
