Tecumseh LME Carburators
45 replies to this topic
#31 IamSherwood OFFLINE
  • 8,390 Thanks
Posted March 28, 2011 - 06:07 PM
Also, just a note.
Had to chase the thread on the nozzle with a 5/16-24nf die, after it was undercut in the lathe.
Also ran a tap up into the carb body to clear the crap out of the threads.
#32 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted March 28, 2011 - 06:25 PM
This morning I googled "Walbro LME Nozzle", and there it was.
I put the altered nozzle into the LME 27, and back on the MF12H.
It's never ran so good.
Had to tweak the governor as per manual, and the the high speed jet once I got
the air filter on, but what a difference.
That is awesome to hear it worked. Will have to try some alternative methods then because I think I have two of them that need work.
#33 IamSherwood OFFLINE
  • 8,390 Thanks
Posted March 28, 2011 - 06:34 PM
I just pulled another one apart. Original nozzle. Couldn't even find the hole in the threads, till I wire brushed, and sprayed
with carb cleaner. And then took a fine wire to clean out the orfice.
#34 IamSherwood OFFLINE
  • 8,390 Thanks
Posted March 28, 2011 - 06:44 PM
I think, that if one was really careful, you could put enough of a groove in the nozzle
just using a dremel, with a small bit. The groove doesn't have to go all the way around.
Just create a notch big enough, because the nozzle will end up seating fairly close to the original cross drilling. So notch, about 45 degrees in either direction. Might be
enough.
Kinda hard to explain in type, but I hope I got my thought across.
#35 IamSherwood OFFLINE
  • 8,390 Thanks
Posted March 29, 2011 - 10:01 AM
I think this method should work as an alternative for those that
don't have a lathe.
Using my damaged/useless nozzle I tried this.
Found 2 -5/16" x24nf nuts.
Took a 5/16" flat washer, and cut part of it off with a hacksaw.
Put the washer in a vise.
With the nuts acting as guides, on either side of the tiny hole, just snugged
up on the washer. Holding the nozzle, with a slight twist, started at it with
the edge of the small flat file.
Not the prettiest thing, but I think it would get the job done. And
it's a controlled landing as opposed to a dremel tool damaging threads
by mistake.
  • NUTNDUN, DH1, broken2 and 1 other said thanks
#36 DH1 ONLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted March 29, 2011 - 03:43 PM
That would work, controls the spot where you want to file the nozzle down.:thumbs:
Good stuff.
#37 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted March 29, 2011 - 04:29 PM
I agree that would definitely work. I think I am going to buy a service nozzle or two just to have on hand but it would be nice to make any regular nozzles that you may already have into service nozzles for future use.
#38 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 05, 2011 - 04:24 PM
What is the significance of the # of the LME carb?
There is many different #'s on the LME carbs.
Is it a version #, and if so, are some better than others?
#39 DH1 ONLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted April 05, 2011 - 04:39 PM
I don't know what the #s mean but I notice 2 different venturie sizes that can be seen with the eye on the carbs I have.
#40 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 05, 2011 - 06:26 PM
This HH100 idle down issue is really stumping me.
I'm gong to pull the carb off the hh120, and try it.
#41 DH1 ONLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted April 05, 2011 - 07:23 PM
That's the best thing to do will tell you where the trouble is, carb or engine.
#42 Tecumseh power OFFLINE
Tecumseh power
  • 1,464 Thanks
  • 1,104 posts
Posted December 23, 2016 - 10:29 PM
They seem to mix up the Tecumseh and Walbro kits for these engines. There is reference to HH100 having Tecumseh carbs on them but I've never seen one on that engine, always see Walbro LME.
Walbro has 2 kits for LME carbs K1 and K2
I know this is an old post but I have been gogleing, some stuff for my hh100s. I can across this post. I don't know if you have ever saw a hh100 with a Tecumseh carburetor. Since this post, And not an lme but they are out there I have a sears custom 10xl a 72 that has a factory Tecumseh carb. Those engines also came with a spacer on the intake port. Because the Tecumseh carb float bowl will hit the block without it. I usually put a 10hp snow king carb on these motors and add a spacer if I have one with a bad lme. You add the spacer. And modify the holes where the throttle rod goes and choke cable and you're good to go. The custom 10 I have is the only one I have seen with the Tecumseh carburetor myself. But you can buy those spacers on ebay used for the Tecumseh carbs so there is more out there.
Edited by Tecumseh power, December 23, 2016 - 10:31 PM.
#43 Tecumseh power OFFLINE
Tecumseh power
  • 1,464 Thanks
  • 1,104 posts
Posted December 23, 2016 - 10:34 PM
#44 Tecumseh power OFFLINE
Tecumseh power
  • 1,464 Thanks
  • 1,104 posts
Posted December 23, 2016 - 10:37 PM
The rest of it
#45 Claysdad2003 OFFLINE
Claysdad2003
  • 1 Thanks
  • 1 posts
Posted June 11, 2017 - 09:18 AM
Looks like I'm a bit late to this tread, only by 6 years. 😂my harbor freight mini lathe is finally gonna have a use full job. Gonna cut out the threads in the nozzle.
