Need advise!
13 replies to this topic
#1 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted February 02, 2015 - 02:47 PM
Getting into things here after being on for a couple of weeks. Almost everyday I come up with something that you guys could help with due to experience, or possibly it's your job. Today's help would be this: I have a closed side Jac., KennyP and maybe others, (slept since then) have hinted it is the larger 16 HP set-up. I purchased AG tires for it and am having troubles getting the bead to seat on the left one. They were both aired up but it has sat for some time. The tires are still almost new, even now. They are hard and stiff. I squeezed them with a cargo strap the first time, but only worked on the right one this go round. Any crazy tips out there?
FC2C5523-F7DF-4F85-9C83-EAADED34950D_zps
Any help would be great. Thanks
Barry
  • A.C.T. said thank you
#2 KennyP OFFLINE
  • 40,847 Thanks
  • 47,077 posts
Posted February 02, 2015 - 03:13 PM
I use this stuff to help the beads seal up.
  • boyscout862 and Sawdust have said thanks
#3 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted February 02, 2015 - 03:23 PM
Kenny, had a feeling you'd chime in. Is it used to just create a wet area the air won't pass? Bead area slicker to pop on the rim? Soften the rubber to conform better? Or don't have a clue, it just works? lol  :D
#4 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted February 02, 2015 - 03:31 PM
The bead sealer helps, grease will work in a pinch too. Soapy water will help the rubber slide on the wheel. I use a male quick connect air fitting over the stem with the core removed to get more air in quicker. The stiff sidewall ags can be tough to mount and may need  the ratchet strap, a few extra hands and a big rubber mallet to get it started.
#5 KennyP OFFLINE
  • 40,847 Thanks
  • 47,077 posts
Posted February 02, 2015 - 03:35 PM
The bead sealer is kind of a glue 9for want of a better word). But it will help stop bead leaks.
#6 boyscout862 ONLINE
  • 13,545 Thanks
  • 9,425 posts
Posted February 02, 2015 - 03:38 PM
I like what tater1195 said  but add a bit. I put the wheel on my changer with the valve stem up and mount the tire loose onto it. I then dry the lower tire and wheel beads with a clean rag and some time. I then push the lower beads together fully. I then only have to fight with the upper. Removing the valve stem core helps alot and upping the air pressure does too. I use strapps and hands pulling up. Eventually, you will win. Good Luck, Rick
Edited by boyscout862, February 02, 2015 - 03:38 PM.
#7 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted February 02, 2015 - 04:27 PM
Good tried & true methods already mentioned. I would say the most important is removing the valve stem for getting that good BLAST of air. Basically it's just a good wrestling match that you'll win sooner or later. :D
  • superaben and Coventry Plumber have said thanks
#8 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted February 02, 2015 - 04:50 PM
I agree , valve stem open and lots of air pressure.
#9 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted February 02, 2015 - 04:54 PM
   there is another way but I do not recommend trying it !!!!!!!!!!   AGAIN I DO NOT RECOMEND THIS !!!!!!  but I have done this and it does work for stubborn tires.  take a can of starting fluid, place the tire OUTSIDE !!!!!!!!!!!!  on the ground with the stubborn bead side up, spray just a very small amount of the starting fluid into the tire, then stand back and throw matched into the space.  POP !!!! your rim will be up on the bead.  leave the valve stem out and be very careful !!!!!!!  I have seen this way tear tires to pieces and people get hurt doing this.
    Please for mine and your sake if you careful and go very sparingly on the starting fluid.
        Pete
  • Coventry Plumber said thank you
#10 mrmd OFFLINE
mrmd
  • 279 Thanks
  • 137 posts
Posted February 02, 2015 - 05:07 PM
I would take the above advice. However I fought some front tires till I was blue. When you get some of these tires they are flat and wrinkled. I finally resorted to this method and had the job done in five minutes. Again, please be very cautious. I sprayed the ether in the tire then onto the ground for a couple feet then light that end of it. Good luck.
#11 Mark K OFFLINE
Mark K
  • 120 Thanks
  • 82 posts
Posted February 02, 2015 - 05:09 PM
You could use a tube.
#12 MH81 OFFLINE
  • 29,978 Thanks
Posted February 02, 2015 - 05:11 PM
Tires that fight me like that, I just tube. WAY easier than arguing with it and for the cost of a tube, it's not worth the high blood pressure or the ether.
Eventually, if they are hard, they will start leaking anyways, might as well save one step in the process.
  • superaben said thank you
#13 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted February 02, 2015 - 06:43 PM
I wouldn't put a tube in a tire with one bead not seated, sometimes adding a tube still won't seat the bead.
This is not how you do it. Hands too close.
Edited by Sawdust, February 02, 2015 - 06:48 PM.
#14 jms180 OFFLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted February 02, 2015 - 07:53 PM
No hair on his hands :rolling:
  • superaben and Sawdust have said thanks
