mower decks
3 replies to this topic
#1 two_bolens OFFLINE
two_bolens
  • 5 Thanks
  • 16 posts
Posted February 02, 2015 - 10:09 AM
Will a mower deck from a case 444 work on a 222?
#2 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted February 03, 2015 - 08:06 AM
Make sure you have the same attachment system.  There were two types:
 - early style (not sure what it's called) - was used for only the first few years of 400 series production
 - fast attach - used for most years of 400 series production
These two attachment systems are not cross-compatible without modifications.
Not sure if the early style was used on the 200 series.
After that, I believe they are compatible, but I'll leave that to someone with more Case knowledge.
Check out this PDF.  First page is a cross-reference of Case tractors and mower deck models:
http://www.pawpawren...rsoll/j1250.pdf
Edited by motobreeder, February 03, 2015 - 08:12 AM.
  • two_bolens said thank you
#3 nlpoole OFFLINE
nlpoole
  • 6 Thanks
  • 12 posts
Posted February 25, 2015 - 11:33 AM
According to my research it will not fit due to hanging and mourning brackets as well as diffrent pully sizing. Would very muchly recommend trying to find the proper mower deck for it as that's what you should be using.
#4 indy2door OFFLINE
indy2door
  • 4 Thanks
  • 5 posts
Posted May 13, 2015 - 08:13 PM
If both tractors have the "Snap Fast" feature then yes, the mower deck will fit either tractor. Shorter lifting links are required for the 222 tho.
