Bolens 1054 Locked up
29 replies to this topic
#16 boyscout862 OFFLINE
  • 15260 Thanks
  • 10022 posts
Posted February 03, 2015 - 10:27 AM
Thanks for all the replys. I'll have a little time this evening to check into it. I have a bad feeling it might be the bearing. I do remember hearing a higher pitched chatter when sitting at idle while changing the angel on the plow.
Yesterday was the first time I've spent much time with this tractor.
Usually I use my Simplicity, but loaned it to a buddy with a pregnant wife so he doesnt get stuck in the driveway during the moment of truth.  :)
No good deed goes unpunished. I favor Bolens and AC/Simplicites too. Good Luck, Rick
  • Simpleton said thank you
#17 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted February 05, 2015 - 11:21 AM
Here she is waiting for me to have some time.
  • blackjackjakexxix and AA Hayes have said thanks
#18 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted February 18, 2015 - 01:38 PM
So I finally got a little shop time today and started to tear into this clutch bearing issue. Am I going to have to drop the front PTO in order to get the drive-shaft out along with the whole clutch assembly? It definitely won't go out the back.
#19 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted February 18, 2015 - 04:36 PM
You dont have to remove the PTO but its much easier if you do
#20 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted February 19, 2015 - 06:38 PM
Wasn't as bad as I thought, considering the coooold temps. Go through a lot of fire wood in a couple hours in the shop.
Bearing was definitely toast.
  • Bolens 1000 said thank you
#21 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted February 19, 2015 - 06:42 PM
Yep thats the culprit!
#22 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22746 Thanks
  • 7519 posts
Posted February 19, 2015 - 08:03 PM
Here are a few pictures of my 1050 when I had it apart last year that may help when you take it apart - should be similar to yours.  Good time to lubricate the needle bearings in the pulley and the splines when you have it apart.
  • Bruce Dorsi, sodisr, Simpleton and 1 other said thanks
#23 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted February 20, 2015 - 09:31 PM
Thank you 29 Chev. for the very detailed pics. That'll help when I go to put it all back together.
#24 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted February 27, 2015 - 04:06 PM
Both parts showed up in today's mail, so I hope to start re-assembly sometime tomorrow. :thumbs:
#25 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted March 04, 2015 - 10:00 PM
Drive shaft is back in the tractor! I just need to align everything and tighten up all the brackets.
#26 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 05, 2015 - 07:10 AM
I just happened to notice something on your tractor that looked familiar. And then I noticed your location, so I went poking around in my pictures and found these:
Looks like our two tractors were sold by the same dealer.
On another note, do you eat at the Hartville Kitchen from time to time?  Wife and I ate there once some time back and the pies are to die for.  Great food too.
  • Simpleton and AA Hayes have said thanks
#27 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted March 09, 2015 - 06:22 PM
I live ten minutes from The Kitchen. My mother baked pies in that place for 26 years. You bet they're GOOD! :rocker2:
Yes that sticker is identical. Small world.
We're only a little over an hour away from each other. Howdy Neighbor. It's about time for those Old Buzzards to return to Hinckley ain't it?
Edited by Simpleton, March 09, 2015 - 06:27 PM.
#28 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted March 17, 2015 - 04:32 PM
Here she is ready to do business. Finished putting everything back together last evening and took it for a test drive. Clutch works great and everything seems ready to roll.
#29 Simpleton OFFLINE
Simpleton
  • 143 Thanks
  • 98 posts
Posted March 17, 2015 - 04:37 PM
I want to thank all who helped me chase down the issue, and especially Dr. Bolens who hooked me up with all I needed to make the repair.
Thank you!
#30 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted March 17, 2015 - 04:39 PM
Glad to hear your up and running!!!
