Locomotive Drive
15 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,282 Thanks
  • 9,771 posts
Posted February 01, 2015 - 07:44 PM
I was sitting at a RR crossing one day when I had a bright idea. . . . .
Has anyone ever powered a GT with an engine driving a generator which drives an electric motor hooked to the rear? Kind of an electric version of a Case hydraulic drve.
  • wvbuzzmaster said thank you
#2 glgrumpy OFFLINE
  • 8,604 Thanks
  • 7,909 posts
Posted February 01, 2015 - 08:00 PM
Isn't that what that lumber yard 4 wheeler-tractor was in old posts?  Seems it was a generator when stopped, but used electric motors to move/drive?  The engine just ran the gen then?  But, not diesel then, ha!
  • LilysDad said thank you
#3 Alc OFFLINE
  • 6,883 Thanks
  • 7,459 posts
Posted February 01, 2015 - 08:06 PM
Like a diesel generator instead of batteries on those electric tractors ?
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 01, 2015 - 08:26 PM
I considered doing it in one of my electric conversions... But abandoned that when I got a GE Elec Trak.
#5 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted February 01, 2015 - 10:29 PM
You're correct. Electric drive motors powered by a gas generator. It was called the Raven. They were off the market but I thought I read somewhere that they were being reintroduced?
#6 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted February 01, 2015 - 11:10 PM
  Wouldn't a DC generator be required?
                                         Mike
#7 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,189 posts
Posted February 02, 2015 - 03:41 AM
                                         Mike
For something small you would probably want DC like old diesel locomotives.simple system but most of the big stuff nowdays  uses AC and controls the speed with Variable frequency.
  • Alc and LilysDad have said thanks
#8 FixItCharlie OFFLINE
FixItCharlie
  • 539 Thanks
  • 344 posts
Posted February 07, 2015 - 10:46 AM
Those motors also have reversing windings in them to reverse the direction of travel. Technically if you can find a DC generator that can handle the load, a DC motor can produce more torque then an AC motor. So for a smaller scale DC may be the better choice & to find the parts just find an electric golf cart. If I remember correctly some of the gas powered golf cart use that type of set up with the gas motor turning a generator that powers an electric motor drive.
Charlie
#9 shorty ONLINE
shorty
  • 5,465 Thanks
  • 5,257 posts
Posted February 07, 2015 - 12:45 PM
It would be a cool idea. Most likely be a challenge to get all the bugs out.
#10 richwoodrocket OFFLINE
richwoodrocket
    16 year old JD lover
  • 147 Thanks
  • 177 posts
Posted February 07, 2015 - 02:46 PM
Yes the raven is like this. It wasn't pulled off the market though, there were a few problems in version one that were worked out and a version two was created. :)
#11 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted February 11, 2015 - 11:25 PM
I have seen the Raven at my local dealer and local Lowes. 13HP generator motor with generator under the seat and all electric drive and blade drive (no belts-3 direct drive electric motors). Only has 110 on the plugs though, no 220 for welder or such. Pricey though. Showing a tag of $4000.
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,282 Thanks
  • 9,771 posts
Posted February 12, 2015 - 12:00 PM
Given this scenario, does a larger engine create more power? . . . Or does any engine that turns the generator at a proper RPM do the job?
#13 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 506 Thanks
  • 387 posts
Posted February 12, 2015 - 12:55 PM
If your really interested about diesel to electric or gas to electric you could look up R. G. LeTourneau. He made a lot of diesel to electric construction and special equipment in the 50's and 60's, he's pretty much considered a pioneer in the field.
#14 richwoodrocket OFFLINE
richwoodrocket
  • 147 Thanks
  • 177 posts
Posted February 26, 2015 - 05:52 PM
My friend and I are making a little project that will have a engine running a generator to power the motors. Kinda like a locomotive I guess.
#15 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,282 Thanks
  • 9,771 posts
Posted February 26, 2015 - 06:59 PM
I hope you keep us posted on your progress.
