How does this Happen?
16 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted February 01, 2015 - 01:14 PM
I was working on a gt and needed another carb, so I pulled one off the shelf. First thing I always do is pull the bowl off to check the condition. Well I pulled the bowl off of this carb and found this. I've never seen something corrode like this and have no clue how it happens. Also the rest of the internal parts in the carb were fairly clean and there wasn't any evidence that gas sat in it for a long period of time. Does anyone have an idea what would cause this?
  • rustyoldjunk, hamman, tinbender7 and 2 others have said thanks
#2 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted February 01, 2015 - 01:20 PM
Wow, that screams "additives" LOL
Probably ethanol, but who knows. You may be able to track it with the color of the corrosion.
  • rustyoldjunk, tinbender7, HDWildBill and 2 others have said thanks
#3 Bolens 1000 OFFLINE
  • 14,810 Thanks
  • 18,058 posts
Posted February 01, 2015 - 01:23 PM
I have seen many heavily corrode but never in those colors!
Probably some bad ethanol gas mixed with water
#4 boyscout862 ONLINE
  • 12,198 Thanks
  • 8,902 posts
It looks like there was water in the bowl for awhile. That is common with the gas now days. What did the bowl itself look like? I've been able to carefully clean many floats. This is one of the reasons that I put Marvel Mystery Oil in my gas. I don't seem to have fuel system corrosion problems when I use it. Good Luck, Rick.
  • tinbender7 and farmerall have said thanks
#5 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted February 01, 2015 - 01:26 PM
The bowl was fairly clean. Only a small spot of dirt where the stuff on the float was touching the bowl. There was nothing to indicate that gas or water sat in this carb for an extended period of time after it was pulled off the engine. I should also add that it has been about 6 years since the engine this carb came from ran last. That could possibly rule out ethanol as a cause.
Edited by farmerall, February 01, 2015 - 01:27 PM.
  • tinbender7 said thank you
#6 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted February 01, 2015 - 01:29 PM
I wonder if that stuff was inside the float (we've all had them leak and eventually sink) and it slowly corroded its way out.
  • tinbender7, farmerall and Genem have said thanks
#7 Freddie1911 OFFLINE
Freddie1911
  • 149 Thanks
  • 98 posts
Posted February 01, 2015 - 02:17 PM
The rifle barrel bore cleaner I think is ethanol based, gives that color as you swab the bore. just my thoughts. Freddie
  • farmerall said thank you
#8 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,570 Thanks
  • 1,298 posts
Posted February 01, 2015 - 02:37 PM
I was having the same thoughts MH. It's cool looking Farmerall,kinda like modern art. :poke: :smilewink:
Edited by rustyoldjunk, February 01, 2015 - 02:41 PM.
#9 HDWildBill OFFLINE
  • 8,972 Thanks
Posted February 01, 2015 - 02:49 PM
I believe moisture got in there while it was sitting on the shelf and caused a reaction on the copper.  Check out these images
Very similar to what you see on your float.
  • Alc, farmerall, boyscout862 and 1 other said thanks
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,541 Thanks
  • 9,828 posts
Posted February 01, 2015 - 03:01 PM
I agree with the others, it's just water. Green is oxidization, the blue is full blown corrosion. The float will be thinner under the bluest parts.
  • Alc, tinbender7, farmerall and 1 other said thanks
#11 superaben OFFLINE
superaben
    Con Man
  • 7,666 Thanks
  • 5,677 posts
Posted February 01, 2015 - 04:59 PM
I think it is something else (I don't know what, but something else) because Cat cannot be right today.
Ben W.
  • Bolens 1000, tinbender7, HDWildBill and 1 other said thanks
#12 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,652 Thanks
  • 9,452 posts
Posted February 01, 2015 - 06:07 PM
It might be viral or bacterial. Be sure to use protective equipment.
  • KennyP, tinbender7 and farmerall have said thanks
#13 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted February 01, 2015 - 10:36 PM
I'll give you a dollar if you eat it.
#14 cpg OFFLINE
cpg
  • 250 Thanks
  • 151 posts
Posted February 02, 2015 - 12:34 PM
You should submit it to a lab; looks like you may have discovered a new life form.
#15 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted February 02, 2015 - 04:34 PM
Wow that is quite a color! Almost looks like it belongs in a beach house as decoration!
