'78 GT18 seems slow. Normal?
35 replies to this topic
#16 johnwesley OFFLINE
johnwesley
  • 32 Thanks
  • 23 posts
Posted February 02, 2015 - 10:07 PM
wahoowad,
According to my Roper 18T manual, which should be same as your Sears, speeds are L1: .85mph, L2: 1.60 mph, L3: 2.56mph; H1: 2.10 mph, H2: 3.96mph, H3: 6.56 mph; R1: 1.02 mph, R2: 2.53 mph. Do yourself a favor and do not put a standard 5/8x83" belt on, get a kevlar wrapped mower belt. It lasts much longer, and its too much problem to be replacing often.
johnwesley
  • MH81, Alc and KennyP have said thanks
#17 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted February 03, 2015 - 05:31 AM
Guess we have ruled out a pulley change then?
#18 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted February 03, 2015 - 07:05 AM
Yes, ruled it out. All looks stock.
#19 MH81 OFFLINE
Posted February 03, 2015 - 07:37 AM
Just wondering, with the OEM specs listed, what speed is it running at now?
Also, are you at 3/4- full RPM's?
#20 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted February 03, 2015 - 11:23 AM
At this point I'll have to get it running up on my neighborhood street and see if my little handheld GPS gizmo will show me the ground speed.
I know my trans is still low on fluid as I changed it recently and never filled it up all the way. I tried but it was so darn slow to fill that I ran out of patience. I think i stopped after 3 quarts of SAE 30 as I knew i was close (think it calls for 3.5 quarts?) and I am not using the tractor for anything yet so didn't figure there would be any heat buildup. I added another 1/2 quart this weekend which was still very slow to fill even after I removed a shifter bolt to let air escape. The cold SAE 30 didn't help - it poured like molasses. I can't see this being responsible for the slowness though since I know I have a good bit of fluid in there.
#21 Alc ONLINE
  • 6,887 Thanks
  • 7,461 posts
Posted February 03, 2015 - 11:32 AM
If the incorrect belt was installed or worn so far that it either sat lower in the groves or bottomed in the pulley cause this problem ?
#22 TAHOE OFFLINE
TAHOE
  • 7,977 Thanks
  • 5,676 posts
Posted February 03, 2015 - 12:17 PM
Tranny holds 5 quarts.
you can remove one of the shifter plate bolts which go through into tranny, this vents the trans and lets oil flow quicker.
Also, get a pan of hot water, even getting it boiling then remove from burner and put quart of oil in there for a bit, helps warm and thin the oil.
#23 johnwesley OFFLINE
johnwesley
  • 32 Thanks
  • 23 posts
Posted February 03, 2015 - 09:13 PM
That should be full rated RPM 3400-3600 RPM.  My old Roper has to wind up tight to cut clean. But, I'll tell you, it's pretty much a small "bush-hog" cutting 3"-4" limbs to mulch. I have taken the mower deck off, and pulled 6"-8" 25' logs out where I could cut them up and haul them off. I have never run out of power, but plenty of times run out of traction with 450- 600 lbs. of  extra weight. That old Onan doesn't know when to .quit.
johnwesley
  • MH81, KennyP and JBRamsey have said thanks
#24 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted February 04, 2015 - 07:15 AM
That is what my GT18 will be doing - pulling stuff and probably never a cutter. I have a mower deck but looks in rough condition. I haven't really bothered to look at it to see what it would take to get it going. That is a project for when it gets warm :D
  • johnwesley said thank you
#25 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted February 06, 2015 - 08:06 PM
Got the tranny full of oil - heating up the oil helped tremendously! Thanks for the tip!
  • TAHOE said thank you
#26 JBRamsey ONLINE
JBRamsey
  • 1,465 Thanks
  • 838 posts
Posted March 09, 2015 - 09:26 PM
Do you have the right size tires on the rears? If you have a shorter tire on the rear, it will run slower. A shorter tire takes more turns(revolutions) to go the same distance.
#27 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted March 09, 2015 - 09:49 PM
rear tires make a big difference. but my big ss 14 and ss15 will outrun my st10s. but my yellow st10 is running suburban tires on back and blue one is running 6-12s you can tell a big difference in speeds on yellow st10 compared to blue st10. but getting to transmissions my ss14 has a keyed axle trans and its a little quicker than my ss15 which i put a splined trans in.
#28 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted March 10, 2015 - 10:37 AM
My GT/18 is running the original 23.5" tires.
#29 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted March 10, 2015 - 11:13 AM
23.5 dont sound right should have 23-10.00-12, 23-9.50-12 or 23-10.50-12. one of those sizes on back
#30 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted October 27, 2015 - 02:00 PM
I just checked and my tires are 23x10.00-12 (pretty sure stock tires). here is a close-up of my pulley system. Looks normal to me.
