4 Bolt bearing hubs for GT fronts
12 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 06, 2011 - 05:09 PM
Probably wrong section but I know a lot of guys with GTs want bearing hubs for the fronts in some applications. Here is a decent option, not sure the thru bore but I bet they would fit most GTs, just thread the end of the spindles to fasten them on properly.
Heavy Duty Go Kart ATV Wheel Hubs 3/4" Bearings TRAILER - eBay (item 370295112344 end time Mar-17-11 12:05:30 PDT)
#2 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted March 07, 2011 - 01:31 PM
I wonder if they would be better than original spindles like with a FEL on?
  • 14,863 Thanks
  • 15,511 posts
Posted March 07, 2011 - 02:14 PM
the guy thats selling them says he'll send them with 5/8" or 3/4", tapered bearings, which ever you want.
#4 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 07, 2011 - 05:49 PM
The tappered bearings are what you want for steering. As for an FEL, I don't know how well the spindles will hold up but the hubs will improve the handling I am sure. Even if you just use them on the snowblower tractor or something, ya know, lot of weight up front.
#5 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted March 07, 2011 - 06:47 PM
Yeah that is what I meant would they hold up better than original spindles with the weight of a bucket full of dirt in a FEL.
#6 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted March 08, 2011 - 11:29 PM
My Case 600 series loader was designed with 1 1/4" tapered bearing hubs from the factory. If your going to try and put a loader on something with 3/4" spindles your probably going to break it pretty quick. I've seen 1" spindles broken but if your going to do it then use the trailer hubs from Northern Tool.
Ultra-Tow High Speed Hub — 4 on 4in., 1250-Lb. Capacity, Single | Hubs | Northern Tool + Equipment
#7 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted March 08, 2011 - 11:41 PM
They look pretty good
#8 mjodrey OFFLINE
Posted March 09, 2011 - 05:15 AM
Alot of small trailer hubs and bearings will also fit some GTs.
#9 Alc ONLINE
  • 7,129 Thanks
  • 7,532 posts
Posted March 09, 2011 - 08:40 AM
Josh tha's good that your thinking ahead, the stamp steel hub on my 2418 broke last year , even though the loader came from the factory it wasn't made like the Case cp7 has .
#10 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted March 09, 2011 - 02:16 PM
Yeah I really like the trailer hubs gonna have to get some lol
#11 grnspot110 ONLINE
grnspot110
  • 4,295 Thanks
  • 2,684 posts
Posted March 09, 2011 - 02:45 PM
I used trailer hubs on my 317 "Special", had to move the backer washer in a little, but not much (replaced it with a plate to hold the fender). ~~ grnspot
Edited by grnspot110, March 09, 2011 - 02:51 PM.
#12 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted March 09, 2011 - 09:26 PM
Looks good is that a 1" axle on a 317?
#13 Frank Morris OFFLINE
Frank Morris
  • 11 Thanks
  • 69 posts
Posted December 14, 2011 - 10:49 PM
BMIkarts has a billet aluminum 4 on 4 hub that uses a 1-5/8" x 3/4" precision bearing, versus the standard 1-3/8" ball bearing most GTs use. They use to sell a steel 4 on 4 hub with a grease zerk that used the standard 1-3/8" ball bearing in 5/8" and 3/4". ALMOST EVERY trailer hub will need a 4 inch stub spindle, for the most part garden tractors have 3" stub spindles, They make a short hub, 63.00 each, that will work on a 3 inch spindle, but most tapered bearing hubs are going to be a 1" bearing. I believe the 1" inch ID L44643 is dimensionally OD the same as L44633 or what ever the number is on the 3/4" tapered bearing. For any FEL application it's best to replace the spindles with 1" or-1-1/4" spindles with 4 inch stubs, that way you can buy the small trailer hubs for about 18.00 and add the 10 inch 4 bolt wheels and tires. I've been testing different application for several years and its not just the weight of the tractor/loader, but the force exerted in turns that requires the need of a thicker stub spindle and tapered bearing. The added benefit of the taller10 inch tire/wheel will be less of a need for power steering, on a large SGT you can even use the 12 inch tire wheel if your running a 26" or larger rear tire
  • mikebramel said thank you
