2 speeds==Fast & Slow?
9 replies to this topic
#1 bus driver OFFLINE
bus driver
  • 3 Thanks
  • 12 posts
Posted January 31, 2015 - 08:30 PM
I just picked up a CC 149.I have changed the rear end oil,filter,cleaned the 2 valves under the shield that goes between the 2 foot rests.While i was driving it today,getting ready for snow,it would all of a sudden go from slow to really fast.If u let it idle and get off the machine(the brakes are worn out and don"t work) the tractor will start to move.Is there an adjustment on the handle to put it in neutral?I did not have time to look at things today.I have a service manual but really don't know what i need to do.Is this an adjustment,something that is worn out in the linkage,or something in the pump.The tractor also seemed a little jerky when u go to slow down or reverse.Thank you for any help.They say we are in for getting some snow by Monday morning.Only time will tell.Rick
#2 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted January 31, 2015 - 08:33 PM
Sounds like a worn trunnion. But I don't know a lot about Cud hydro's!
#3 bus driver OFFLINE
bus driver
  • 3 Thanks
  • 12 posts
Posted January 31, 2015 - 08:56 PM
What is a grunion and where is it located?
#4 bus driver OFFLINE
bus driver
  • 3 Thanks
  • 12 posts
Posted January 31, 2015 - 08:58 PM
should have said"what is a trunnion"
#5 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted January 31, 2015 - 09:40 PM
"Grunion" sounds like a bunion on your groin! OUCH!  Glad it's your trunnion!  :D
  • KennyP and Lauber1 have said thanks
#6 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted January 31, 2015 - 11:54 PM
It does sound like the trunion ...if it goes from not moving to break neck speed with just a little movement of the hydro handle , then you've probably lost or broke the trunion springs .
The photo's are of a 782 rearend but is the same as the one in your 149
 The second photo shows the trunion springs after I rewelded the worn out  trunion .
  • olcowhand, MH81, KennyP and 2 others have said thanks
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted February 01, 2015 - 08:23 AM
Grunion is a fish.
#8 MH81 OFFLINE
Posted February 01, 2015 - 09:50 AM
Grunion is a fish.
Weren't they in a book?
#9 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted February 01, 2015 - 05:55 PM
There's a great site that talks about the trunnion springs.
http://cubfaq.com/trunionrepair.html
A bunch of pieces that have to work together in just the right way.
  • TomLGT195 said thank you
#10 queball OFFLINE
queball
  • 8 Thanks
  • 11 posts
Posted June 07, 2015 - 03:25 PM
