Depth wheel question
4 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 13, 2013 - 07:44 PM
How do you measure how high the depth wheel is set from the bottom?
Is there a best depth?
#2 MH81 OFFLINE
Posted November 13, 2013 - 08:02 PM
do you think you could measure how high the depth wheel is set from the bottom?
Rule of thumb is 1/2 the size of plow.
12" should dig 6"
10" should dig 5"
Etc.
  • superspeedex said thank you
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 13, 2013 - 08:13 PM
ok thanks i made a stop on my speedex plow and didnt really know how to set it i have all the power in the world but it buries its self even when i lay it flat  so now ill set it at 5 and call it good for a semi good tune also how far from the square edge of you furrow to the inside of wheel should it be cause mine is 13 inches and i flipped the wheels and didnt know if it will be to far out of the furrow for the plow to be digging
#4 MH81 OFFLINE
Posted November 13, 2013 - 08:31 PM
On a 10" plow, you shouldn't be cutting more than 10" or you'll leave unplowed areas.
Usually, a 10" plow set at 9" from the inside of the wheel will work out pretty well.
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 13, 2013 - 08:49 PM
So ten inches like this  ill remeasure tommorow and post a pic for you to see what i am working with
