Finally Started the JD 100!
33 replies to this topic
#16 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 14, 2015 - 07:53 AM
Looking good! But what I really like is your saw horses made our of old iron fence posts, at least that's what they look like. I pounded in more than my share of them back in my youth on the Iowa farm where I grew up.
Harlan
That's exactly what they are, some old light weight posts!  Work good for welding & the nubs hold parts up a bit for painting.
  • Texas Deere and Horse, johndeereelfman and Genem have said thanks
#17 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 14, 2015 - 05:10 PM
Panting the front axle w/linkage, PTO linkage & frame today:  HPIM1516.JPG  HPIM1515.JPG  HPIM1517.JPG
After first of four coats of JD "Ag Green":  HPIM1518.JPG
  • Texas Deere and Horse, KennyP and johndeereelfman have said thanks
#18 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 15, 2015 - 05:55 PM
Had some paint chips in one of the side panels, so it got sanded down & painted with the footrests:  HPIM1521.JPG
Engine housing & replacement muffler were painted today:  HPIM1520.JPG  HPIM1522.JPG
And, started putting it all back together:  HPIM1523.JPG
Just hope I can remember where everything goes!   :wallbanging:
#19 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 15, 2015 - 06:18 PM
Quick question for you Lowell. I see you primed your muffler, and I'm assuming you'll be painting it with high heat black. Do you always prime you mufflers before using the high heat? I used to do the same thing, but eventually the black started flaking off. I found that the primer wasn't made for high heat temperatures, and if I just used the high heat paint directly, I never had flaking problems since. Just something to think about if you didn't already know it.
The 100 is coming along good. Looking forward to seeing the final results.
  • Texas Deere and Horse, WHdbJD and Sawdust have said thanks
#20 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted February 15, 2015 - 06:20 PM
It's gonna be pretty!
  • grnspot110 said thank you
#21 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 15, 2015 - 07:28 PM
No, I didn't use primer, just cleaned it up with a wire wheel then 3 coats of Rustoleum " High Heat Flat Black".
  • Texas Deere and Horse and johndeereelfman have said thanks
#22 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted February 15, 2015 - 07:39 PM
Nice progress! I bought a little John Deere 111 last fall, got it for $50 but the electric pto clutch don't work and the deck is messed up. VERY solidly built little lawn tractor compared to other LT's I've had. I'd imagine you have a 10hp Briggs? The 111 is probably the same as a 110 with an 11 horse. Also mine has no side louvers, sides are open.
Edited by TokyoDrift99, February 15, 2015 - 07:39 PM.
#23 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 15, 2015 - 07:53 PM
8 HP Briggs!
#24 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 16, 2015 - 06:09 PM
Have the grip for the lift lever & steering sector bearing kit on order. Along with a fuel shut-off that "departed Denver sorting facility at 3:45 Feb 10", according to USPS tracking!
Getting closer:   HPIM1524.JPG  HPIM1525.JPG
#25 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted February 16, 2015 - 06:49 PM
Lowell, You certainly are doing a nice job on the 100. It is going to look great when you get her done.
What transaxle do those use?
#26 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 16, 2015 - 07:52 PM
Thanks!
Peerless 1200, 3 speed forward-1 reverse.
#27 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 20, 2015 - 12:34 PM
Finishing up the 100 today:  HPIM1526.JPG
I have the grip for the lift lever & some sand tread tape ordered for the footrests.  Brought the deck up from the back shed to put on this afternoon.
  • Gabriel said thank you
#28 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted February 20, 2015 - 04:14 PM
Very nice, Lowell!
#29 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 20, 2015 - 05:20 PM
The grip for the lift lever came in the mail today, so it's on.  Put the deck on after dinner:  HPIM1530.JPG  HPIM1531.JPG  HPIM1532.JPG
It's now under cover in the back shed until spring!
It will spend  quite a bit of time riding in the 22B cart during show season this summer:  HPIM3053.JPG
Edited by grnspot110, February 20, 2015 - 05:35 PM.
  • KennyP, GTpicker01 and Gabriel have said thanks
#30 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted February 20, 2015 - 06:18 PM
Sweet looking tractor! Even if it is Green & Yeller!
