Question about John Deere thrower.
13 replies to this topic
#1 propane1 OFFLINE
propane1
  • 8,715 Thanks
  • 4,124 posts
Posted January 30, 2015 - 12:22 PM
One for sale in my area. Ad says it will fit 318/332. It does not show pulleys for the belt. When belt comes down from engine are there pulleys to direct the belt to the thrower? The pulley on the thrower is horizontal and has an idler tensioner for the belt. I believe this will fit my 140. But need a picture of how it directs the belt from the tractor to the thrower. Does it use the mule drive for the deck? Any help would be great, Noel
#2 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted January 30, 2015 - 12:41 PM
The 49 I have came off of a 318. You need the proper belt to install it on your 140. There is a gearbox that sends the power to the side of the blower to drive the screw. It does not use the mule drive either. I will look up some pics on my laptop.
  • propane1 said thank you
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted January 30, 2015 - 12:50 PM
Is the pulley dead center on the blower or on the side?
#4 propane1 OFFLINE
propane1
  • 8,715 Thanks
  • 4,124 posts
Posted January 30, 2015 - 12:57 PM
Looks to be in the centre , but only saw pictures. Noel
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted January 30, 2015 - 01:16 PM
In JDPC they say, that the 47 inch 2 stage will fit the 318 / 322. Maybe a look to jdpc can help you, Noel.
Edited by jd.rasentrac, January 30, 2015 - 01:18 PM.
#6 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted January 30, 2015 - 01:25 PM
Here is the 49 off of the tractor
Edited by Trav1s, January 30, 2015 - 01:25 PM.
  • jd.rasentrac and propane1 have said thanks
#7 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted January 30, 2015 - 01:27 PM
I think you can see the right angle in the shaft in this pic
#8 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted January 30, 2015 - 01:53 PM
We don't need this implements here in Hesse this year. This morning it started to snow and this noon the snow on the streets was gone.
JD doesn't sell tractor throwers since more then 40 years in germany - only walk behind. No market here.
Edited by jd.rasentrac, January 31, 2015 - 04:18 AM.
  • Oldford and propane1 have said thanks
#9 propane1 OFFLINE
propane1
  • 8,715 Thanks
  • 4,124 posts
Posted January 30, 2015 - 04:59 PM
My mistake, stupid me.  The picture in the ad for the thrower that I looked at, the pulley looked horizontal, but it is vertical. This hooks on to the tractor and the pulley lines up with the engine pulley. So the belt runs vertical up and down. The picture I looked at is taken from the top down, I thought It was from the rear looking at the thrower from behind. Thanks to Trav1s for the pictures to help me figure out what I was looking at. So it does not need pulleys like a mule drive.  Sorry for all the confusion, thanks again trav1s, Noel
  • Trav1s said thank you
#10 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted January 30, 2015 - 05:22 PM
Gladly!
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted January 30, 2015 - 05:37 PM
I got fooled looking at that first pic, too. I was wondering how they got the mounting frame tipped down 90°!
#12 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted January 31, 2015 - 04:20 AM
Here's a german thrower - in jammies...
  • KennyP and propane1 have said thanks
#13 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 31, 2015 - 09:07 AM
I have a 49 as well but the drive is torn down right now. Noel, check that angle grove for slack. The gears can be worn but also the keyways get wallowed out on the shafts. The gears are very expensive but last I checked they are still available.
#14 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted January 31, 2015 - 09:58 AM
Also, it seems that Deere Corn Head gear box lube is what is best for the gearbox.  I need to get the 49 blower info I have gathered into one place.
