REO ROYAL DELUX reel lawn mower
17 replies to this topic
#16 fourpines OFFLINE
fourpines
  • 100 Thanks
  • 29 posts
Posted March 18, 2015 - 10:33 PM
Do you happen to have a part number for those?
I have some complete wheels and tire assemblies.  I'll pull the manual tomorrow and check if you don't know the number.
Ben W.
Ben, I do not have the p/n. the model is wk21,the wheels do not have a hub cap,the wheel is a solid
cast,with the REO molded in the wheel cast. see pick's
  • DB1, superaben and CharlesDes have said thanks
#17 GaryM OFFLINE
GaryM
  • 3 Thanks
  • 2 posts
Posted April 24, 2015 - 11:53 AM
http://www.ebay.com/...=item1e8b8246c9
Mike.  Not sure if these Chinese tire skins are close enough to work on our Reos.  Hub size seems to be biggest difference.  Their actual size is 1 7/8 W X 10 H w/ a 7 1/8 Hub space and 9 1/4 inside diameter.
The original Reo tire seems to be ~ 1 7/8 X 9 1/2 with a 6 1/2  hub space.  Guessing the important dimension is the tires inside diameter and I am hesitant to cut off the still somewhat functional tire to get that measurement.  Any luck on your end?  Gary.
  • fourpines said thank you
#18 fourpines OFFLINE
fourpines
  • 100 Thanks
  • 29 posts
Posted April 27, 2015 - 08:20 PM
Gary, still no luck. these reo's seem to be rare birds.
