O-scale train engine
78 replies to this topic
#31 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,955 Thanks
  • 1,866 posts
Posted February 09, 2015 - 08:18 PM
Sorting thru the bag of side rods and valve gear, I find that most of the parts that I need are there.
I got out the expansion links and radius rods for one of the chassis assemblies.
The mounting brackets for these two parts are about .070 wider than the expansion link and radius rod together.
I made up a small spacer and soldered it to the inside of the radius rod to take up the space.
Here is a look at how the two parts now fit into the mounting bracket.
You can see the spacer to the inside of the rod with a straight pin holding both parts in place.
There wasn't any rivets or pins for joining the linkage arms together so I'm using small nails that are .040 diameter.
The parts are joined together with the nail going thru both parts and then the nail is soldered on back side.
Then the excess length of the nail is cut off and the end is filed down a little to smooth it off.
Here are the return crank, eccentric rod and expansion link assemblies.
And the radius rods and reverse lift link assemblies.
There aren't any union link arms so I'm going to have to make them.
I have end pieces that were cut off of some valve linkage arms that I shortened for another project.
These are trimmed to the correct length and the cut end is rounded off.
Then a .045 diameter hole is drilled thru all four pieces.
Here are the finished union links.
There is no provision for mounting the union links to the crosshead assembly.
Looking at photos of the 2-4-4-2 type locomotives, I see that the bottom flange on the crosshead extends down below the lower crosshead guide and the union link attaches to it.
Similar to this drawing.
I can't solder an extension to the lower part of the crosshead because the design of the guide assembly would then not allow the crosshead to be removed from the guide bars.
So I need to make a bracket that will bolt onto the face of the crosshead that the union link can attach to.
This bracket also needs to set out about .100 from the face of the crosshead in order to line up with the valve linkage.
I drew out the design for this bracket on a sheet of .012 thick brass.
A hole is drilled thru the end of the bracket.
This will be trimmed out to form a notch in the end of the bracket.
The bracket is cut out and the notch is cut into the end.
The bracket is bent to shape and the mounting holes are drilled in place.
The end with the notch is bent so that it fits over the steam cylinder shaft on the front of the crosshead.
This will keep the bracket from rocking back and forth when it is screwed to the center of the crosshead.
The union link and combination lever are attached to the bracket.
Here is the bracket attached to the crosshead.
This whole assembly can be removed so the crosshead can be slid out of the guide bars.
  • Texas Deere and Horse, wvbuzzmaster, IamSherwood and 5 others have said thanks
#32 Cvans OFFLINE
  • 6,669 Thanks
  • 6,134 posts
Posted February 09, 2015 - 11:34 PM
It's really fun to watch your progress. I have one complaint though, green has been my tool color since 1968. This ain't good.  :D
  • jdcrawler said thank you
#33 KennyP ONLINE
  • 38,512 Thanks
  • 45,987 posts
Posted February 10, 2015 - 05:32 AM
Wow! Too small for me to work on! Good job, Ray!
#34 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted February 10, 2015 - 10:59 AM
Holy small !! I used to love working on little things like that, but not so much now LOL, hence the 1/3 scale Sopwith pup.
#35 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,955 Thanks
  • 1,866 posts
Posted February 12, 2015 - 03:53 PM
Made up the two steam supply pipes that run from the side of the steam dome down to the steam cylinders on the rear chassis.
These are formed from 3/16 diameter brass tube.
It was an interesting job to bend these so they wrap down around the boiler and curve forward to end up along side the casting for the steam cylinders.
Here is a view of the two tubes on the underside of the boiler.
The straight brass tube was bent to shape using this tool for bending brake lines and the ends were cut off at and angle.
The end with the angle cut on each tube fits snugly to the side of the steam cylinder casting.
Holes were drilled thru the foot boards and in the sides of the steam dome.
The steam supply pipes were put up thru the holes in the foot boards and fit into the sides of the steam dome and then soldered in place.
Here is the left side with the chassis mounted on.
And the right side.
Here is how they look from the top.
Edited by jdcrawler, February 12, 2015 - 04:05 PM.
  • Texas Deere and Horse, wvbuzzmaster, IamSherwood and 4 others have said thanks
#36 KennyP ONLINE
  • 38,512 Thanks
  • 45,987 posts
Posted February 12, 2015 - 04:11 PM
Won't be long and you'll be building a 'fire' in this thing! Looks great!
#37 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,930 Thanks
  • 5,976 posts
Posted February 13, 2015 - 10:04 PM
Amazing work. Do you use some sort of magnification? Like one of those big super lighted on an arm? I'd need to aim two together
#38 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,955 Thanks
  • 1,866 posts
Posted February 14, 2015 - 09:46 AM
I have a 4 inch magnifing glass mounted on a flxable arm.
Edited by jdcrawler, February 14, 2015 - 09:50 AM.
#39 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted February 14, 2015 - 12:30 PM
Surprised you dont make working model steam engines
#40 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,955 Thanks
  • 1,866 posts
Posted February 19, 2015 - 03:51 PM
There is about a 3/8 high open space between the rear chassis frame and the underside of the cab.
I'm going to make op a pan to fill this space.
The pattern is first made up out of a piece of cardboard and then transferred to a piece of brass.
The finished pan is bent to shape and the brake cylinders and levers are soldered to it.
Here is how it looks mounted under the cab.
I also got the foot boards made for each side of the smoke box and the headlight is mounted.
  • Texas Deere and Horse, IamSherwood, KennyP and 2 others have said thanks
#41 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Posted February 19, 2015 - 03:54 PM
Very impressive Ray, I would love to have the patents to do that kind of detail work.
#42 KennyP ONLINE
  • 38,512 Thanks
  • 45,987 posts
Posted February 19, 2015 - 04:39 PM
Nice work, Ray!
#43 Cvans OFFLINE
  • 6,669 Thanks
  • 6,134 posts
Posted February 19, 2015 - 07:32 PM
Sure is looking nice Ray!
#44 UncleWillie ONLINE
  • 15,681 Thanks
  • 8,767 posts
Posted February 19, 2015 - 08:16 PM
Beautiful
#45 Sawdust ONLINE
Sawdust
  • 5,685 Thanks
  • 3,383 posts
Posted February 19, 2015 - 08:29 PM
Coming along very nicely Ray, outstanding detail. Have you ever used the glass jewels that go into the light housings. They have a silver back & reflect the smallest amount of light to the point it looks like their illuminated. It's been fun following your craftsmanship.
