O-scale train engine
78 replies to this topic
#16 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 01, 2015 - 09:05 PM
Would using one of those ultrasonic units be the answer
for cleaning?
  • jdcrawler said thank you
#17 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,954 Thanks
  • 1,866 posts
Posted February 02, 2015 - 01:51 PM
If your displaying this one I would find it hard to cover it with paint. Nice
We're those originally painted? So pretty just polished.
I haven't been painting the engines that I've built in brass.
for cleaning?
Might be.   I'll have to check into that.
Edited by jdcrawler, February 02, 2015 - 01:53 PM.
  • toomanytoys84 said thank you
#18 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,954 Thanks
  • 1,866 posts
Posted February 02, 2015 - 01:53 PM
Working on mounting the pilot and making up the deck plate on the front.
The framework for the deck is soldered to the underside of the deck plate.
Drilling a .040 diameter into the end of a .062 diameter brass rod.
The air pipe fits into the hole in the brass rod and is soldered in place.
Then the brass rod is bent to shape.
The air line is then mounted to the top of the deck plate with two "U-bolts".
  • grnspot110, Texas Deere and Horse, wvbuzzmaster and 6 others have said thanks
#19 Sawdust ONLINE
Sawdust
  • 5,680 Thanks
  • 3,381 posts
Posted February 02, 2015 - 04:20 PM
Good to hear no paint on these. Looking real nice Ray. Drilling that hole looks interesting. My Dad now retired was a machinist for the Dover Corp. He always kept me supplied with drill bits because they would never sharpen anything just throw them away. He once gave me a piece of tape & said here's a drill bit. I opened it up & honest it looked like a fine hair. I had to look under my magnifier to actually see it was a drill bit.
Your project is a good one to follow & to know how much we all have many interesting talents, skills etc. to share.  :thumbs:
  • grnspot110, Alc, jdcrawler and 2 others have said thanks
#20 Cvans OFFLINE
  • 6,668 Thanks
  • 6,134 posts
Posted February 02, 2015 - 10:02 PM
You must not have much run-out in that chuck. Working on little stuff like that won't tolerate much. Is that a 3 jaw independent chuck?
not seen one like that.
#21 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,954 Thanks
  • 1,866 posts
Posted February 02, 2015 - 10:25 PM
The lathe is a Sherline  model #400 and the chuck is dead on.
  • Cvans and Sawdust have said thanks
#22 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,954 Thanks
  • 1,866 posts
Posted February 03, 2015 - 04:27 PM
Turning a piece of plastic down to make the insulating hub for the leading and trailing truck wheels.
The wheel is pressed onto the plastic hub.
With the wheel then clamped in the chuck, the back of the plastic hub is faced off and the hole is drilled for the axle.
Two of the wheels have the axle shaft pressed in place now.
Here are the finished wheels.
The frame for the trucks is cut from a piece of sheet brass.
The axle shaft for the wheels fits nicely in the piece of small brass tube.
The sides are bent over to make the truck frame ridged and give it some thickness when viewed from the side.
The front lip on the truck frame is also bent over and the small brass tube is soldered in place.
There is a small hole drilled in the top of the small brass tube to oil the axle shaft.
Here is the finished leading truck mounted on the chassis.
This is how the chassis looks so far with both trucks installed.
  • grnspot110, Texas Deere and Horse, wvbuzzmaster and 7 others have said thanks
#23 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted February 03, 2015 - 04:38 PM
Boy Ry, that is some real fine "Small" machine work your doing there, looks GREAT. :thumbs:
  • jdcrawler and Cvans have said thanks
#24 KennyP ONLINE
  • 38,490 Thanks
  • 45,977 posts
Posted February 03, 2015 - 06:33 PM
Awesome work, Ray! Glad you have the patience to take the pics for us to see!
#25 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 03, 2015 - 10:14 PM
Why is it i now cant wait to see the smoker box mocked in place? :thumbs:
Excellent work as always Ray.
#26 UncleWillie OFFLINE
  • 15,676 Thanks
  • 8,763 posts
Posted February 03, 2015 - 11:09 PM
I want to know how big the magnifying glass you use for that work is.
#27 Cvans OFFLINE
  • 6,668 Thanks
  • 6,134 posts
Posted February 03, 2015 - 11:43 PM
You really operate at both ends of the spectrum don't you. From installing a Cummins in a truck to installing trucks on a locomotive. Amazing. Next you will be carving the Constitution on a fly's wing.  :smilewink:
  • jdcrawler, IamSherwood, KennyP and 1 other said thanks
#28 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 04, 2015 - 07:11 AM
Truly a talented man. I like just watching him work.
I can't wait to see the fly wing thing happen. :smilewink:
#29 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,954 Thanks
  • 1,866 posts
Posted February 07, 2015 - 06:43 PM
I thought that I was going to be able to purchase a smoke box from PSC but they didn't have any with a large enough outside diameter.
So it looks like I'm just going to have to build one.
Starting by turning down a brass bushing so it fits snugly into the front of the boiler.
The bushing was then cut in half so I have two support rings for the smoke box.
Then I cut a strip from a sheet of .020 thick brass and bent it around a piece of pipe to start forming the shape for the smoke box.
The brass strip is wrapped around one of the support rings.
This ring sticks out a little and will be the part that fits into the front of the boiler.
Both support rings are soldered inside the brass strip to form the smoke box.
The smoke stack and the boiler front are soldered in place and the finished smoke box is soldered onto the front of the boiler.
The hinges, hand rail and engine number were missing from the boiler front so those parts were also soldered on.
  • wvbuzzmaster, KennyP, LilysDad and 2 others have said thanks
#30 KennyP ONLINE
  • 38,490 Thanks
  • 45,977 posts
Posted February 07, 2015 - 06:51 PM
That looks better!  Can't wait to see it with wheels under it!
