jacobsen homelite hydro leak
24 replies to this topic
#16 KennyP ONLINE
  • 40,148 Thanks
  • 46,773 posts
Posted January 29, 2015 - 08:44 PM
You don't want one, they're $100! Got a pic somewhere, just haven't found it as yet.
#17 Beast Jacobson OFFLINE
Beast Jacobson
  • 12 Thanks
  • 22 posts
Posted January 29, 2015 - 09:05 PM
Maybe if mine has a crack, but $100 ouch only paid 300 for the whole tractor.
#18 FixItCharlie OFFLINE
FixItCharlie
  • 551 Thanks
  • 352 posts
Posted January 29, 2015 - 09:34 PM
When I did the conversion to spin on filter on my LGT 145 the filter is a Fram PH16.
http://gardentractor...s-fluid-change/
Is from when I did mine.
Charlie
#19 Beast Jacobson OFFLINE
Beast Jacobson
  • 12 Thanks
  • 22 posts
Posted January 29, 2015 - 09:55 PM
Awesome now I can use the old dodge fitler wrench again. Heck might even have a filter lying around .
  • T Guiles said thank you
#20 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted January 29, 2015 - 11:51 PM
Welcome great looking GT. I love the Ford's I have and they are real workers. The folks on here really know their stuff.
#21 KennyP ONLINE
  • 40,148 Thanks
  • 46,773 posts
Posted January 30, 2015 - 08:57 AM
Starting to work  on my new to me jake. I have a hydro leak around the filter housing. Anyone had this issue and how much and what kind of fluid to refil? What filter will fit?  Appreciate  any advice.
attachicon.gifpost-66775-0-42939400-1422566146.jpgattachicon.gif20141018_103054.jpgattachicon.gif20141018_103119.jpg
The reason I asked if the lines were tight as there is a drip on one of the fittings in your pic!
#22 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted January 30, 2015 - 09:10 AM
If you have the spin on filter setup , you will want to make sure the adapter fittings are tight in the filter housing! This is where mine on my 125 was leaking from.remove them and clean the threads spotless and reinstall with red loc-tite/ sealer they will not leak or ever loosen up again until warmed ( 350+°) . GM uses this stuff on all their threaded coolant fittings and coolant sensors good stuff .
#23 KennyP ONLINE
  • 40,148 Thanks
  • 46,773 posts
Posted January 30, 2015 - 09:11 AM
The filter was loose I tightened it, but didn't  stop it. Maybe  a new one will solve it. What do you mean by an in line?
In post 5, 3rd pic, Will has one peeking out in this thread.
#24 TomLGT195 OFFLINE
TomLGT195
  • 4,015 Thanks
  • 2,883 posts
Posted January 30, 2015 - 05:58 PM
I  found the box, it's a Stens part# 120-380 they can be found online too.
#25 Cat385B ONLINE
    HAZMAT CAT
  • 14,262 Thanks
  • 10,109 posts
Posted January 30, 2015 - 06:42 PM
By the way make sure you clean the fins on the tranny
I was going to suggest that, also. Way too dirty to be cooling effectively.
