1973 Ford LGT 165 about replace engine
10 replies to this topic
#1 RussellTP OFFLINE
RussellTP
  • 10 Thanks
  • 7 posts
Posted January 29, 2015 - 04:07 PM
Will the John Deere 216 16 hp kohler engine direct fit on Ford LGT 165 on the oil pan amount?
  • rustyoldjunk and T Guiles have said thanks
#2 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted January 29, 2015 - 04:42 PM
:wave: Welcome to the forum! Is that a 341AQS engine? Wide base or narrow? You might want to check this thread.
  • rustyoldjunk, boyscout862 and RussellTP have said thanks
#3 boyscout862 ONLINE
  • 13,693 Thanks
  • 9,476 posts
Posted January 29, 2015 - 05:47 PM
Welcome to GTT. I have an LGT125 open side. I am rebuilding the engine and it is different from one out of a Cub. The block to base bolt pattern is different. Pics will make your questions more exact. Check out our Manuals Section for info when you need it. Good Luck, Rick
  • rustyoldjunk said thank you
#4 TomLGT195 OFFLINE
TomLGT195
  • 4,103 Thanks
  • 2,930 posts
Posted January 29, 2015 - 06:26 PM
Welcome to GTTALK, pics would certainly help!
  • rustyoldjunk, KennyP and RussellTP have said thanks
#5 rustyoldjunk ONLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,698 Thanks
  • 1,339 posts
Posted January 29, 2015 - 08:31 PM
The 200 series Deere engines are different than most small pan Kohlers. Most small pan Kohlers don't have the "ears" cast into the block that the big pans use to mount,in other words most small pan Kohlers won't take a big pan.This is not the case with the 200 series Deere engines. They DO have the "ears cast into the block. The 200 series Deere tractors use those "ears" to mount the engine to the tractor. So if you are needing the type of block that will take a small or bigger "deep" pan you have picked the right engine.
Edited by rustyoldjunk, January 29, 2015 - 08:33 PM.
  • KennyP and RussellTP have said thanks
#6 RussellTP OFFLINE
RussellTP
  • 10 Thanks
  • 7 posts
Posted January 29, 2015 - 08:55 PM
Thank for my welcome to forum. Here the picture of block. I believe that I am seeing k341AS on engine cover.
Edited by RussellTP, January 29, 2015 - 08:58 PM.
#7 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted January 29, 2015 - 09:04 PM
So the bolts come up through the bottom? That has the balance gears, best make sure the bearings are very good in them. Or take them out! They will make a hole in the block if they come apart!
#8 Gabriel OFFLINE
Gabriel
  • 1,449 Thanks
  • 1,863 posts
Posted January 29, 2015 - 10:32 PM
Welcome to GTTalk!
#9 RussellTP OFFLINE
RussellTP
  • 10 Thanks
  • 7 posts
Posted February 10, 2015 - 09:10 AM
Would the k341 crankshaft fit all kohler K341S, K341AQS and K341AS?
#10 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted February 10, 2015 - 09:50 AM
Yes. The Letter Designation at the end distinguishes certain characteristics such as: K341S is electric start, AQS is having a special oil pan, quiet model, and Electric Start, and AS is oil pain and electric start.
The crankshaft is all the same though. Always double check with a micrometer though!
Edited by FilledTires, February 10, 2015 - 09:50 AM.
  • RussellTP said thank you
#11 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted February 10, 2015 - 10:59 AM
If you are planning to put it in the block above, be sure to get the balance gears timed along with the cam! I think the difference in cranks was more into the output (PTO) end of the shaft.
