On my 1886 there is a shaft going through the disk and brake assembly , what holds it all together at the end of the shaft. The disk just wobbles something is missing like a snap ring
Brake Disk Assembly
Started by
Dlelicker
, Jan 28, 2015 09:59 PM
3 replies to this topic
#1
OFFLINE
Posted January 28, 2015 - 09:59 PM
#2
OFFLINE
Posted January 28, 2015 - 11:27 PM
Hi, your disk has splines on it that go onto the shaft that is also splined,my guess is either that shaft is worn or the disk is worn,I have a complete set up on ebay right now,it either goes off Friday or Sunday,can't remember off hand right now,I go by blackjackjakexxix on there also,if you need more info pm me, Thanks, Rick
- Dlelicker said thank you
#3
OFFLINE
Posted January 28, 2015 - 11:47 PM
I took a look,it goes off on Friday evening
#4
OFFLINE
Posted January 29, 2015 - 09:23 AM
Thanks Rick for answering, will check your listing on ebay. At the end of the spline ( right side looking from rear of tractor )something has to press system together. I can see spline but no cap or snap ring to hold together
- blackjackjakexxix said thank you
