The '59' Suburban That named itself 'Rusty Gold'
123 replies to this topic
#46 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 10, 2015 - 06:23 PM
And Todays Update with more pictures. !
My uncle Patrick got mad and took a hammer to 'Rusty'
Seriously  though - he did break the glass sediment bowl for the gas . Was trying to fit a new gasket.
Anyone know where I can get one?
The ignition was worked on more , added some clips to the kill wire to keep it out of the way (not shown) .
 There is a lot of hot spark now !
Looks funny without the hood. The Choke cable was loosened up and got it to free up and operate right.
And the best part !! I went over to look at Pat's pile of scraps laying by the cut-off saw to find a piece of steel to make a 'bottom bracket w/ pins' for the 3 pt. hitch . Lo & Behold there laying in the pile was exactly the part I needed , exact size with the holes in the right place already bent - I literally picked it up out of a pile of scrap and bolted it on  !! All that was needed was to enlarge the side 1/2 holes to 5/8 for the pins. He told me this was a prototype piece for work he was bidding on years ago !
So after some minor alterations ! One 3 point hitch with bottom turning plow attached !!
It was a very productive couple of days work ! I am very happy with how this thing is going and the only real worry is if the Carb. will work or not .
  • MH81, KennyP and classic have said thanks
#47 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted June 10, 2015 - 07:33 PM
Sounds like this uncle knows his stuff! Learn from him.
  • MGP59DB said thank you
#48 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 10, 2015 - 09:07 PM
Oh - I have been listening and watching and doing what I can , but he is an experienced man on this and other things.
He showed me a complete rebuilt MonkeyWard motor B/S with the same Carb as this machine. His passion was Model A's he has 2 of them out at the river.
Old Iron all over the place.
To me it was just a great day spent with him !
Ever since I saw his 1960 DB 917-60613 sitting there , I have wanted one of these .
Now- to work on my own with him is a pleasure , and memories I will always have of him and how truly talented he is!
He made clips , tapped holes for screws to hold them , replaced spring steel kill switch , replaced the reverse spring , Found screws for the hood , had a box for me to search thru for the 3 pt hitch bolts , and they were there ! He showed me so many little things on how to measure and figure out what taps to use for which size holes . Tricks for putting wires on so they won't short circuit or fall off again .
My Uncle Pat is an amazing man !! I am taking him to the Gilmore Antique Tractor and Garden tractor show in Hickory Corners , Mich. at the Car museum on the 27th of this month !
It will be fun to bum around and see if we can find that replacement glass bowl !!
Also going to Fruitport Mich. this coming Saturday for a smaller local show.
  • Alc, KennyP and classic have said thanks
#49 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted June 10, 2015 - 09:25 PM
You can get a new complete sediment bowl for less than 15 bucks online. I probably have a glass too if needed.
Looks like a few of us got a few of these going this season!
  • KennyP and MGP59DB have said thanks
#50 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 12, 2015 - 09:03 AM
Thanks Jabel ! I did order the whole assembly ! $14.96
I was wondering if anybody can tell me about what looks like a 'governer or 'rev' limiter , There is this armature attached to the front of the motor and it is just bolted down so it doesn't move ??
We loosened it and it works like a limiter or something ?
I am also hoping someone can give me the belt sizes , I am wanting to replace these , they look OK , just thinking.
  • classic said thank you
#51 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted June 12, 2015 - 03:18 PM
On Your Tag Is It A 143302 OR 143402? Looks like you have parts from an airvane governor setup at one time. maybe someone switched it over at some time to a mechanical governor.
Edited by jabelman, June 12, 2015 - 03:19 PM.
#52 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted June 12, 2015 - 08:16 PM
I can get the belt sizes since I replaced the belts on mine. The old belts looked fine on mine, but they would slip since the belt surface was like plastic from age. The new belts made a huge difference once everything was adjusted properly.
#53 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 14, 2015 - 09:09 AM
I have the 143302 , ser 17690 ,
#54 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted June 14, 2015 - 10:32 AM
You should have a airvane type governor then
#55 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 21, 2015 - 08:20 AM
Yup , According to Pat , his machine has that same set-up and it is still working , so we will have to see what can be done with it. We will be going back at this Tuesday , he was out of town last week and I don't have keys to the shop.
I hope to get some of the attachments blasted and cleaned up , need to get the gas system back in place , then maybe test it to see if it runs !!
We'll see .
I am still excited about this thing ! This is my first 'baby' .
Edited by MGP59DB, June 21, 2015 - 08:23 AM.
  • MH81 and classic have said thanks
#56 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 24, 2015 - 08:33 PM
Another fine day of resto work !
Surprise !! I show up at the shop to work on Rusty today and I'll be damned , Pat went and manufactured (fabricated) a Pulley guard for my tractor !! He went out to his machine at his river property , got all of the measurements , and 'made' one for my machine !! Holy Crap ! I couldn't have been more shocked.
He put it on the tractor (unpainted) and didn't say a word . I saw it immediately and was like - what the hell? What a great guy !!
We then fabricated mounting brackets for it and it is ready to blast and paint.
I also blasted all of the attachments 3 pt hitch , mule drive , front and back plows. We did some looking at the clutch assembly and it needs to be taken apart , the reverse pulley is frozen to the forward and the clutch is not seeming to be working at all . I just looked at the exploded assemblies and it definitely needs some attention.
The Seat and Hood were blasted and primed for paint as was the gas tank and straps(gently).
I didn't get any pictures today but will have some next time .
#57 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 26, 2015 - 12:46 PM
The Paint shop is doing Well ! (me)
after/\
For contrast - before\/
Edited by MGP59DB, June 26, 2015 - 12:52 PM.
#58 MH81 OFFLINE
Posted June 27, 2015 - 11:27 AM
Awesome that its all coming along.
Nice paint job(s)
#59 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted June 28, 2015 - 01:15 PM
Had a good time at the tractor show yesterday ! Not 1 DB 4 wheeler.
#60 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted July 01, 2015 - 07:56 PM
This thing is still moving along .
Took the clutch pulleys off and cleaned all the parts , this was a witch !! It took a torch and a lot of muscle but it finally freed up .
Working great now - Hooray !!
Just working on little details now , small dents in hood repaired and cracks welded . Ready to fill and paint .
The gas tank is on ! Seat is ready to do final sanding and paint .
The pulley guard is painted along with the engine cover and pull starter . Other misc items.
A decent days work . I am happy to see this clutch assembly in good condition , that was worrying me .
