The '59' Suburban That named itself 'Rusty Gold'
123 replies to this topic
#16 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted January 29, 2015 - 12:07 AM
Does the engine have compression when you turn the flywheel?
          Yes . I am hopeful.
Edited by MGP59DB, January 29, 2015 - 12:07 AM.
#17 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted January 29, 2015 - 07:53 AM
Looks like a decent sarter. I would like to have one of those in my collection someday.
  • MGP59DB said thank you
#18 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted January 29, 2015 - 10:59 AM
By the way, I'm fallible myself so join the club. First of all I would spray a little penetrating oil on the flywheel screen screws and the four screw holding the coil in place. Let it sit overnight then try removing the screws after lightly tapping the screws with a small hammer. The rust also needs to be cleaned off of the outer surface of the flywheel. Use only sandpaper to do this. Don't use a wire brush or steel wool.
You will need to remove the recoil starter clutch to remove the flywheel, and you should get the correct puller to remove the flywheel. Once the flywheel is off, you will find the points and condenser under a tin cover. I can help you out more tomorrow since it's getting late now.
I was looking over the actual parts list for this motor  . Hmmmmm now what is that the red arrow is 'point'ing to.
I won't be able to do much till it warms up , Have to get ahold of a puller .
Thanks to you all, I do have an idea of what I need to do , where to begin,  to figure this thing out .
In the mean time , I am making arrangements to get the shroud and pull starter . I do have the rusty bits soaking with penetrating oil.
I will be checking the fuel system seals .
#19 classic ONLINE
classic
  • 5,171 Thanks
  • 2,231 posts
Posted January 29, 2015 - 12:22 PM
That part that the red arrow is pointing to is the condenser, and the points assembly is just above it and is number 343. It shouldn't take too much to get that engine running.
#20 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted January 29, 2015 - 01:31 PM
Ya , I don't know why Pat would have said this doesn't have them , ??? He is getting up there -75 this year in 2 weeks , and some health issues .
I don't think it should be too difficult to get things going on this . Ordered up all the tires and tubes -
'Rusty' only had one of his lever knobs left - I got a replacement set from sears - Ya - I will be on the lookout for originals , cheap plastic doesn't do much for me.
But it does cover the sharp points for now.
#21 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted January 31, 2015 - 12:15 AM
I look at this thing and just want to go out and play with it . Can't wait till things warm up.
#22 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted January 31, 2015 - 08:18 AM
I don't think I ever seen those small turf tires like that. Aeen them on Cub 180-184's and some gold course mowers, but never that small.
Looks good sitting there, bet you are eager to get it going.
#23 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted February 01, 2015 - 09:01 AM
I have all of the 'correct' tires on the way already ! I hate to see 'him' like this .
On a different note - My Mother had a mild heart attack yesterday and I am her care taker at this point .
So I may be out of touch here for awhile.
  • KennyP, TAHOE and Sawdust have said thanks
#24 KennyP ONLINE
  • 37,495 Thanks
  • 45,506 posts
Posted February 01, 2015 - 09:21 AM
Prayers for you all you folks!
  • classic and MGP59DB have said thanks
#25 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted February 03, 2015 - 08:50 AM
Prayers for your mother. I hope all is well.
Geno
#26 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted February 03, 2015 - 07:53 PM
Good looking project, glad your rescuing it. Praying for a quick recovery for your Mom.
#27 IWLBCNU OFFLINE
IWLBCNU
  • 123 Thanks
  • 160 posts
Posted February 06, 2015 - 10:55 AM
I'll be getting that shroud to you this weekend, finally realized same person as on another site ;)
  • MH81 and MGP59DB have said thanks
#28 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted February 06, 2015 - 05:28 PM
Yes one in the same !! I did get one shroud from Don .
It looks good on this !! I have sent you the check Jeff . I will decide which parts of what to use after I see both- the other will be used for a special project I want to do .
Mom is home today now . And My Dad made it thru his Triple by-pass - things are settling down so I can get back on track with this a little bit. Just need warmer weather to do the rims painting . Before I mount the tires . I can mess a bit with the motor - but it gets cold fast out in the garage.
I like it - so nice to see this motor the way it should look.
Thank You to all who wished my Parents well during their recent ordeals . I am hoping they both have good recoveries . Oh I didn't mention my father also had heart surgery yesterday in Tucson ,Az . I actually had to go to Battle Creek for an MRI myself to try to get an Idea of what is causing me some of my own problems. Sheesh , It has been a bad month for my family .
I am glad to have a diversion like this to get my mind elsewhere.
This is my Jeep in the driveway last week. Wish I had a Bulldozer!
Edited by MGP59DB, February 06, 2015 - 05:35 PM.
  • Sawdust and classic have said thanks
#29 MH81 OFFLINE
Posted February 06, 2015 - 08:25 PM
Sorry to hear you guys are having troubles, but very glad Mom is home, Dad made it thru and things are gonna settle down some.
If your ticker is giving you fits, don't try to shovel that jeep out.
#30 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted February 08, 2015 - 11:22 AM
My ticker is not the problem .
Just for fun this morning.\/
