I give up on Kohlor Command 25
47 replies to this topic
#31 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted January 28, 2015 - 10:03 PM
Both exhaust valves and not the intakes, I would assume?
I'm guessing the pressure pulse from the backfire pushes the valves open so far the piston smacks them and bends them.
  • Auburn David said thank you
#32 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted January 28, 2015 - 11:42 PM
First of all, the engine has to be shutting off the fuel at the solenoid while at the same time killing the spark.  If you have spark while the key is in the off position, you have a problem with the tractor wiring that needs to be fixed.
What oil are you running in the engine?  Kohler calls for 10w30 and since the Command has hydraulic lifters, I would follow Kohler's recommendations.
Ben W.
#33 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted January 29, 2015 - 05:59 AM
Oh, gotcha! And spark not needed with hot muffler internals.
#34 Alc ONLINE
  • 6,154 Thanks
  • 7,051 posts
Posted January 29, 2015 - 06:19 AM
Would the back fire be from un-burnt fuel in the hot exhaust igniting,  kind of like as a kid ,, shutting the key off on a stick shift car then turning it back on " BOOM"  lol
#35 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted January 29, 2015 - 06:39 AM
Yep, gotta be.
  • Alc and Auburn David have said thanks
#36 skyrydr2 OFFLINE
  • 3,788 Thanks
  • 3,347 posts
Posted January 29, 2015 - 07:16 AM
If your fuel shutoff valve is sticking, and they do big time... BANG!! And I have seen them bend a rod doing this,both connecting rod and pushrods so make sure that thing is working or let it idle for a few minutes then shut it down . I have always shut mine down after a cool down period and never had a bang.
#37 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted January 29, 2015 - 07:26 AM
I always idle a couple minutes to cool a gas engine's exhaust too. When I forget.....BANG every time.
#38 Alc ONLINE
  • 6,154 Thanks
  • 7,051 posts
Posted January 29, 2015 - 08:31 AM
Back to a question I had about , "why would they want you to shut it off at 1/2 throttle ?"   Would  it be to push more air through the exhaust at  shut off ?
#39 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted January 29, 2015 - 11:50 AM
Thats just what they recommend on these engines..I have had two folks (the sears tech,and a small engine mechanic)tell me that these engines do not kill the spark..only the gas.
#40 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted January 29, 2015 - 11:52 AM
1/2 throttle shut off is only for the engines with the fuel shut off valve,low idle is used for the ones with standard carb and EFI.
#41 KennyP ONLINE
  • 33,268 Thanks
  • 42,720 posts
Posted January 29, 2015 - 04:46 PM
Ain't no way I'll shut off any engine at half throttle!
#42 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted January 29, 2015 - 05:46 PM
Just going by what they say to do..I think its a bad design myself.
#43 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted January 29, 2015 - 06:07 PM
It's your hot muffler's guts that is igniting the explosion.  If there was still spark to ignite fuel getting past a faulty fuel solenoid, then it would burn that fuel in the combustion chamber.  BUT, if (and spark should be cut off) fuel is getting past the solenoid, it gets pumped right on through to a very hot muffler, which sets off the explosion inside the muff.  The only way to avoid the possibility is to let the engine slow idle for a couple minutes.  None of my gas engines have the fuel solenoid and as long as I idle to cool the muffler, I never have a backfire.  But when I forget, it's almost guaranteed.
  • Alc, KennyP and Auburn David have said thanks
#44 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted January 29, 2015 - 09:47 PM
 Man, I find that very hard to believe.
#45 Alc ONLINE
  • 6,154 Thanks
  • 7,051 posts
Posted January 30, 2015 - 06:19 AM
Me neither , maybe someone could check this out some time .
