I give up on Kohlor Command 25
47 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted January 28, 2015 - 02:35 PM
some time back this engine (on a GT5000)backfired on shut down and bent the pushrods and valves on one of the heads..after some time I located the parts and repaired it..well this morning it did the same thing..I had already checked the sheer pin and such,replaced the carb and have it a good clean up and tune up..looks like I will be installing a B&S on this one.
This engine probably has less than 300hrs on it from new..I am the only owner of it.
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted January 28, 2015 - 02:36 PM
Darn..I misspelled Kohler..
#3 glgrumpy ONLINE
  • 8,604 Thanks
  • 7,909 posts
Posted January 28, 2015 - 03:45 PM
That darn piece of junk!  Want My address, so you can send it here and I'll get rid of it for you??
  • Auburn David said thank you
#4 boyscout862 ONLINE
  • 12,826 Thanks
  • 9,157 posts
Posted January 28, 2015 - 04:20 PM
Sounds like cam timing. Good Luck, Rick
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted January 28, 2015 - 04:21 PM
I just dont get why it keeps doing this,it is a great running engine..lots of power..but it has always had a little backfire on shut down.
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted January 28, 2015 - 04:25 PM
Sears came out and looked at it right after I got it and they said it was the fuel shut off valve on the carb..so they replaced the carb for free..that helped for some time till it started again after a few weeks..thats why I replaced the carb with the new head this time..and it still did the same thing.
Edited by Auburn, January 28, 2015 - 04:27 PM.
#7 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted January 28, 2015 - 04:33 PM
Is it being shut down by the book?  Almost every one of them will backfire if idled down before kill.
  • rustyoldjunk, superaben and Auburn David have said thanks
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted January 28, 2015 - 04:55 PM
Yea,little above 1/2 throttle before shut down..Kohler sent me a letter in the mail about how to shut them down(sorta like a service bulletin),I have always followed it to the tee,and I only run ethanol free gas in it like they recommend.
seems to be a common problem per Youtube..
#9 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted January 28, 2015 - 04:59 PM
Sorry this happened again to you . I never head of a special way to shut off a engine ,hope someone would share more about it
Ok I'll take that back ,I'll wait a little on our work trucks before shutting off the engine to cool the turbo down
Edited by Alc, January 28, 2015 - 05:01 PM.
#10 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted January 28, 2015 - 05:05 PM
From what I understand when you turn this engine off it doesn't kill the spark,it just closes the fuel valve?
#11 propane1 ONLINE
propane1
  • 8,708 Thanks
  • 4,121 posts
Posted January 28, 2015 - 05:06 PM
I always set the speed down then after a minute or so, down a bit more, then on idle, then off. I just like to let them cool of a bit before shut down.  Noel
#12 propane1 ONLINE
propane1
  • 8,708 Thanks
  • 4,121 posts
Posted January 28, 2015 - 05:10 PM
Maybe thats why it does it, The spark would still be lighting the left over fuel. It would be a lean mixture which may cause the backfire.  Just a thought, Noel
#13 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted January 28, 2015 - 05:15 PM
#14 propane1 ONLINE
propane1
  • 8,708 Thanks
  • 4,121 posts
Posted January 28, 2015 - 05:40 PM
That seems odd, but I guess you have to do what the book says,  Noel
#15 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,444 Thanks
  • 5,761 posts
Posted January 28, 2015 - 05:50 PM
The reason you shut the engine down like the manual says is TO PREVENT S/D backfiring!  So if your engine had bent valve components I'll wager the Flywheel key has been stressed or partially sheared and the spark timing would be a bit off and cause the ruckus you are seeing.  Just a thought-  Check it out if you like
Edited by WNYTractorTinkerer, January 28, 2015 - 05:51 PM.
  • rustyoldjunk, Alc, boyscout862 and 2 others have said thanks
