Positive ground starter
4 replies to this topic
#1 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted January 28, 2015 - 10:39 AM
I have a vertical shaft Briggs and Stratton 16hp motor that seems to have a positive ground starter. I thought they were all negative ground. In order for it to engage and spin the motor it has to have the positive ground connected to the block and the negative to the post on the starter.
Anyone have any thoughts on this?
#2 boyscout862 ONLINE
  • 12,852 Thanks
  • 9,172 posts
Posted January 28, 2015 - 11:05 AM
Wrong starter? Brushes in wrong? I haven't seen anything with a positive ground since the sixties and it was a British car. Good Luck, Rick
  • Traill95 said thank you
#3 DougT ONLINE
DougT
    Dog Approved
  • 6,927 Thanks
  • 4,996 posts
Posted January 28, 2015 - 11:16 AM
I would say the brushes are connected wrong. The small engine starters are polarity sensitive depending on the brushes. The big starters aren't polarity sensitive and will turn the same direction regardless of how the cables are hooked.
  • Alc, Traill95 and boyscout862 have said thanks
#4 Bud W ONLINE
Bud W
  • 326 Thanks
  • 303 posts
Posted January 28, 2015 - 12:21 PM
The starter case that has the magnets glued in is mounted upside down! I fixed a briggs starter that the magnets came loose and when I put it back together, I got it upside down and the starter turned backwards. I took it back apart and turned it around and it worked.
#5 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted January 28, 2015 - 05:26 PM
I took the starter apart and the magnets were loose from the housing and one of them was broke. Luckily I have two of these motors so I have another starter and it turns the right direction. Thanks.
