* * * * - 1 votes
Walk behind of the day
357 replies to this topic
#76 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted February 16, 2015 - 09:37 PM
yep by all means if the called out person doesn't respond, then someone post one. Who the next victim, I mean collector to show off his or hers, as I know theres at least one female in the walk-behinds.
Okay, Jeff...I just found your challenge or invitation.
This is a walk behind but of another kind. A 1937 National Mower Company Sickle Mower.
 "Pulls itself you only steer."
If anyone has another one; please, post it or provide any information.
We only found an ad that was in a mag.
  • Gtractor, LPBolens, Alc and 5 others have said thanks
#77 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 16, 2015 - 09:48 PM
very wicked looking thing, thanks for joining us.
  • DB1 said thank you
#78 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted February 17, 2015 - 09:59 AM
My 1957 Versa-Matic with Sriggs & Brat-Stone engine.  :smilewink:
This tractor came with the blade pictured and tire chains. Tires are loaded.
I also have, but acquired separately, a sickle mower, plow, disk, cultivator, and hauling cart.
  • DougT, LPBolens, Alc and 9 others have said thanks
#79 brownboystoys OFFLINE
brownboystoys
  • 121 Thanks
  • 146 posts
Posted February 17, 2015 - 06:56 PM
Nice looking versa a matic. You say you have the cart for behind it. I also have one. But someone took the hitch off to make it fit a tractor.I was wondering if you could get me a piture and measurements of this bolt on part. I am making the seat bracket now. Thanks for any info on these parts.Jody Brown
#80 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted February 18, 2015 - 07:25 AM
Thanks BBT.
I can't load new pictures to my computor - only pics I have are old.  I will say the cart has a very standard looking sleeve hitch, not the Bolens Quick Hitch like the plow has.  The cart is genuine Bolens with brakes for a walk behind but didn't come from a Versa-Matic.  Since that pic was taken several years ago I took the blade off and put the dirt plow on.  it takes up less room in the shed that way.
Those that know,  would the cart for the Versa-Matic have the same quick hitch as other implements such as the plow?
Can anyone get the pics and measurments for BBT?
Sorry I can't be more help.
#81 LPBolens OFFLINE
LPBolens
  • 1,415 Thanks
  • 971 posts
Posted February 18, 2015 - 01:27 PM
I am guessing that the trailer uses the same hitch as the sulky. The part on the trailer tongue would look to be similar to a sleeve hitch. The part that goes on the walk behind is set up to swivel so the trailer can go over uneven ground independent of the tractor. I have included a picture of the hitch I am talking about mounted to a Bolens Power Ho. Note that it is an axle mounted in a bracket.
  • Gtractor and brownboystoys have said thanks
#82 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted February 18, 2015 - 02:52 PM
Walk behind of the day.
  • DougT, Gtractor, Alc and 5 others have said thanks
#83 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 18, 2015 - 04:39 PM
I can get some pics and measurements tonight off mine for the hitch.
#84 Tbrooks OFFLINE
Tbrooks
  • 508 Thanks
  • 326 posts
Posted February 18, 2015 - 05:47 PM
That seems to be a common part to be missing. Mine is also missing it. Hopefully someone will post pics with dimensions.
#85 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 18, 2015 - 06:21 PM
I guess im not following this to well. What hitch is it we need? One for a sulky or something else.
#86 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 18, 2015 - 09:07 PM
The flat stock on the sides of the tougne is 1/8" thick. 6" across the bottom. 4" up the front and 1 1/4" at the back. The hitch (where the pin goes through) is 5/16" thick. The hole for the pin is 1 1/4" from the inside of where the bend starts. Hole is 11/16" dia. The length of the hitch towards the front is 1 7/8". The height of the hitch I'm not positive on. Someone has been playing around with it and it isn't original anymore. But I'm thinking it should be 4 7/8" tall, outside measurement. The hitch I have on a couple tractors in 5" inside so I'd think there should be some room for movement. The bolts are 4 1/2" center to center.
IMG_20150218_193432_814.jpg IMG_20150218_193540_264.jpg IMG_20150218_193619_704.jpg IMG_20150218_193833_728.jpg IMG_20150218_194027_427.jpg
Any more questions I'll try and answer them.
  • Gtractor, Lauber1, brownboystoys and 1 other said thanks
#87 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted February 18, 2015 - 10:11 PM
Thanks Nato for stepping up and helping where I couldn't.  :thumbs:
  • Nato77 said thank you
#88 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 18, 2015 - 10:42 PM
i'll slip one in here before bed, but its not official until tomorrow. This is a 1946 Page tractor, I believe it to be the first model of them, having the spoke wheel, instead of the solid one. No hood on the first yr one, but there might have been another model that yr were you could have gotten one, and an optional single headlite. If I remember right its power by an AHEN engine of 4.3 hp. Just thought I had to have it, restored it and never have started it up since, that was 15yrs ago.
  • Gtractor, Alc, Nato77 and 5 others have said thanks
#89 brownboystoys OFFLINE
brownboystoys
  • 121 Thanks
  • 146 posts
Posted February 18, 2015 - 11:02 PM
attachicon.gifIMG_20150218_193432_814.jpgattachicon.gifIMG_20150218_193540_264.jpgattachicon.gifIMG_20150218_193619_704.jpgattachicon.gifIMG_20150218_193833_728.jpgattachicon.gifIMG_20150218_194027_427.jpg
Thanks for the pictures and measurements. I will be starting the cart as soon as I get the versa matic done. thanks again to all who put the time in to helpout with these projects.
#90 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted February 19, 2015 - 11:15 AM
Man, I love spoke wheels!
  • Lauber1 said thank you
