* * * * - 1 votes
Walk behind of the day
357 replies to this topic
#316 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,648 Thanks
  • 5,046 posts
Posted June 18, 2016 - 11:00 PM
Took me a second to figure out what these extra bars were for.  On a Springfield.
Edited by Gtractor, June 18, 2016 - 11:01 PM.
  • Lauber1 and Clifford Bridgford have said thanks
#317 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 19, 2016 - 12:56 AM
ok ill bite, none of mine(3) has those on it.
  • Gtractor said thank you
#318 DougT ONLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,061 posts
Posted June 19, 2016 - 05:55 AM
Was it for keeping the mud from building up in the rim?
  • Gtractor and Lauber1 have said thanks
#319 Gtractor ONLINE
Gtractor
  • 9,648 Thanks
  • 5,046 posts
Posted June 19, 2016 - 08:14 AM
Jeff,  my one Springfield doesn't have them either.
Very good guess Doug!   ......  but not correct.   The seller thought they were mud scrapers too.
They are part of the reverse.  Basically the backing plate of the hubs must be stationary because of the way Quick designed their reverse.  This bar clips to the very back of the main frame to hold the backing plate and keep it from rotating with the axle.
  • DougT and Lauber1 have said thanks
#320 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 19, 2016 - 08:15 AM
first I thought of that, but It didn't make real sense to me to put the tractor in ground that wet, as how could you get the tooling to work. later I wondered if it was some part of a reverser system, similar to what db used where a rod moved apart in the hub.
#321 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 19, 2016 - 08:17 AM
wow I guess I was thinking in the right direction, so who has this and are there more pictures of the system.
#322 Gtractor ONLINE
Gtractor
  • 9,648 Thanks
  • 5,046 posts
Posted June 19, 2016 - 08:23 AM
Sorry,  that's the only pic I took. The tractor was for sale at a tractor shows flea market.  I had a full load with my display so no way to haul it home.
I wanted his Wizard w/sickle mower but it had already sold.
  • Lauber1 said thank you
#323 Gtractor ONLINE
Gtractor
  • 9,648 Thanks
  • 5,046 posts
Posted June 24, 2016 - 08:48 PM
Neat mower selling at auction tomorrow just down the road from me.
Update:  it brought $75 and went to a member of the family.  He said he'd have went to $100.
Edited by Gtractor, July 12, 2016 - 06:39 PM.
  • Alc and Columbia236 have said thanks
#324 DougT ONLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,061 posts
Posted June 24, 2016 - 09:12 PM
Looks like it even has the rare starter cup guard!   :D
  • Gtractor and Nato77 have said thanks
#325 DougT ONLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,061 posts
Posted July 05, 2016 - 08:26 PM
Here is a tractor that you don't see everyday. It is a big Simplicity. Wards sold this as the team-trac. The engine dates to 37. This was being used as yard art for over 10 years. The exhaust had been plugged. It still turns over and has compression. It doesn't roll though.
  • Bolens 1000, Gtractor, Alc and 6 others have said thanks
#326 jimmy G OFFLINE
jimmy G
  • 1,267 Thanks
  • 805 posts
Posted August 11, 2016 - 06:11 PM
One for the DB crowd, 1949-1953(near as I can tell) brush and tree saw, blade rotates 90 degrees for buzz rig work, grease fittings inside the wheels, clutch is controlled with a shifter fork and pressure must be applied constantly (a nice safety feature)the paint scheme is a dead ringer for my 917.5751 and should look great as a pair. As rusty as it looks this was a barn find and everything but the throttle is free
  • Gtractor, Alc, Lauber1 and 2 others have said thanks
#327 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 13, 2016 - 12:17 AM
had a lot of parts and pieces lying around, so I decided to build my own version of a walking tractor. Started with a wards/simp chassis  add some wooden handles, that are offset to the right,  used a DB motor mount to get the engine farther forwards, installed a modern 900 series briggs, then sat down and built a vator based on a PJ design, complete with a one lever gauge wheel adjuster. plan to use this one in the garden, and its only 21 1/2" wide.
weed slayer 005.JPG weed slayer 006.JPG weed slayer 010.JPG weed slayer 004.JPG weed slayer 002.JPG weed slayer 008.JPG
  • earthgrinder, Gtractor, Alc and 6 others have said thanks
#328 Gtractor ONLINE
Gtractor
  • 9,648 Thanks
  • 5,046 posts
Posted August 13, 2016 - 06:47 AM
Awesome build!!!
But you shouldda had a "what is it?" contest to entertain people before tellin them it was a hodge-podge of parts.
#329 DougT ONLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,061 posts
Posted August 13, 2016 - 08:03 AM
It's the Lauber Mule.
#330 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 13, 2016 - 10:13 AM
another lady friend of mine calls it the weed slayer. If it don't rain more today, we plan to test it in the garden this afternoon.
  • DougT said thank you
