102 muffler
10 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted January 26, 2015 - 10:42 PM
will a pancake style muffler work ok on 102 ? If so I won't worry about buying a elbow and use the new exhaust on the 129.
#2 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted January 27, 2015 - 12:23 AM
Not without the correct plumbing. The elbow that's factory has no threads on the muffler end to screw on a "pancake" muffler. To make one work you'll need a elbow with male threads on the engine side and female on the muffler side. Plus I'm pretty sure you'll need a piece in between the female and muffler to clear the cast front, and that would be male on both ends....
Sounds right in my head, hope it makes sense.   :thumbs:
Edited by zippy1, January 27, 2015 - 12:24 AM.
#3 KennyP OFFLINE
  • 37,506 Thanks
  • 45,509 posts
Posted January 27, 2015 - 05:29 AM
You can make it work, but those are a lot louder!
#4 Bolens 1000 OFFLINE
  • 14,906 Thanks
  • 18,104 posts
Posted January 27, 2015 - 09:03 AM
The pancake mufflers bolt on, you'll need the studs that go into the block to secure it, see pic below
http://bolenspartsan...8-08-48-068-01/
#5 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted January 27, 2015 - 09:20 AM
I have this one and a 1" black iron pipe the 6" long.
http://www.lowes.com...Id=1189873&Ntt=
the pipe I got
http://www.lowes.com...ollow&cId=PDIO1
Edited by bbuckler, January 27, 2015 - 09:24 AM.
  • VintageIronCollector said thank you
#6 mtoney OFFLINE
mtoney
  • 824 Thanks
  • 685 posts
Posted January 27, 2015 - 06:17 PM
You will want the proper muffler, they can be found over on ebay or thru distributors like Maple Grove Distrbuting out of Galveston IN.  Your ears will thank you later in life.  Those pancakes are loud and dont last either.   The other option is a upright set up like a farm tractor using the IH-1 muffler used on the Farmall Cubs.  Just make sure you make a brace to the top of the engine to support the weight of the upright muffler, this protects the cast engine block.  You can get a IH-1 muffler and a proper flapper style rain cap at any good farm/fleet store like Tractor Supply Co, or Rural King ect.    Mike
  • bbuckler said thank you
#7 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted January 27, 2015 - 06:24 PM
the pipe I got
as long as the pipe is long enough it should work. I had to replace the muffler on my Allis B-212 and did what you have.
#8 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted January 27, 2015 - 06:25 PM
Here's how mine looks
#9 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted January 27, 2015 - 07:36 PM
the pipe I got
Don't think it'll work without the elbow. It's going to hit on the cast front.
#10 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted January 27, 2015 - 07:41 PM
I think I'm going to go ahead buy the actual elbow piece and put the right one. I got to wait anyway to get a 1" tap
#11 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 27, 2015 - 09:04 PM
Remember these two things. It needs to be a 1" NPT pipe tap... And you will want to grease your tap, not oil, and this is why. With oil lubricating your tap you will have metal shavings stuck everywhere and to everything. With grease lubricating your tap you will have metal shavings stuck in the grease. When you clean out the grease, the shavings come with it. Plus you don't waste a lot of oil or grease in a horizontal application. Additionally, not adding oil and metal into your engine is a good plan.
