Massey 1655 Electric PTO
40 replies to this topic
#31 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted January 30, 2015 - 08:22 AM
I was waiting quietly. ;-)
:thumbs:
#32 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 30, 2015 - 08:28 AM
Wow George, you need to get that fixed. It sure has a lot of wear on it.
Yeah, that's nasty.
So, the option would be what? Engine tear down,  weld up and machine it
back to spec?
#33 KennyP ONLINE
  • 51034 Thanks
  • 52658 posts
Posted January 30, 2015 - 09:04 AM
I happened to be out in garage, measured shaft on my B48M, 18 HP onan-  1 1/8" ,
Daniel was right :wallbanging:
:poke:  :thumbs:
My B48G is 1-7/16" along with the B43. Haven't measured the P220 as yet, but it has an electric clutch on it.
#34 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 30, 2015 - 09:09 AM
Yeah, that's nasty.
back to spec?
If I were taking it apart, i'd just replace the crank with low hour used.
  • Texas Deere and Horse, IamSherwood and adolphsson09 have said thanks
#35 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 30, 2015 - 09:12 AM
Or? why not turn it down, and put a smaller ID clutch on it. Something
more common and less expensive.
#36 Texas Deere and Horse OFFLINE
  • 15112 Thanks
  • 15570 posts
Posted January 30, 2015 - 10:36 AM
If it runs really good and doesn't need to be tore down, I might take a good file to it with it running and get it trued up. Then get a bushing turned for it and use a tall key, as long as it fits the shaft tight it will last forever.
  • limebuzz and IamSherwood have said thanks
#37 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 31, 2015 - 07:09 AM
If it runs really good and doesn't need to be tore down, I might take a goo file to it with it running and get it trued up. Then get a bushing turned for it and use a tall key, as long as it fits the shaft tight it will last forever.
That's a possible too, but looking closely at that picture, there won't be much of the keyway
left, by the time it gets cleaned up to the diameter at the front of that groove. Like you say, that
key and bushing will have to be a good tight fit, or it won't be a good thing.
#38 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
Posted February 02, 2015 - 09:02 AM
I don't plan on tearing the motor down. I will swap it out and repower with something else before I did that. It does run good though and it would suck to see it go. I was thinking about attempting to build it up myself with the welder and take my time cleaning it up. I could have the engine running and true it up with a file but not sure how it would turn out with the motor vibration.
Worse case scenario I can do like Daniel mentioned and get a taper lock pulley which would basically avoid the worn area.
#39 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
Posted February 02, 2015 - 08:41 PM
So is my idea too far fetched or could it possibly work?
#40 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 02, 2015 - 10:13 PM
George, it can be done for sure.  If it were me, I'd build it up, then run the engine while CAREFULLY run an angle grinder to take it down close to spec, then maybe finish with a file.  I am known to do things that aren't so safe sometimes, so take it very slow & again....careful!
#41 Texas Deere and Horse OFFLINE
  • 15112 Thanks
  • 15570 posts
Posted February 02, 2015 - 10:43 PM
Use a piece of Copper key stock in the keyway and it will be like new in the keyway. And do use a angle grinder to get it close and then file it to size.
