Snow Thrower Chute control cable
17 replies to this topic
#16 FirefyterEmt OFFLINE
FirefyterEmt
  • 456 Thanks
  • 859 posts
Posted January 30, 2015 - 05:50 PM
The cable is a bit tricky, you need to have the cable going through the hole in the crank with the middle of the cable.  Wrap the cable around the tube maybe 4 turns in one direction, and 4 turns in the other direction to start. I find that using a pair of spring clamps to hold it in this place while you work on the chute end helps a LOT!
 Now point the chute forward and take the cable end for the winding below the hole and go around the front of the chute and to the bolt.  I loop it through the cable stops and wait before your crimp them.  Now run the cable from the top wrap around the back of the chute to the bolt.  You will need to play around with the cables a bit, but I hope that makes sense.
after a while you should get the amount of wraps and length of the "ends" correct.  You do want it to shoot back ad maybe 8 o-clock and 4 o-clock if facing forward is noon. (I can take more photos or a video of how it works if that helps)
You will also need to use a sleeve to stop the bolt for the cables.  The bolt only has a little bit of thread and if the bolt is too long, or does not have a sleeve, it will hit the blower head and lock it solid in place.   I have a lathe, so it was easy to make a custom bushing, but a simple sleeve on the bolt will stop the bolt from going in too far, and allow you to tighten the bolt so it does not fall out.
Here is what I did on mine.
This is the sleeve, along with some nice sleeves I made for the belt cover for the pulley's
  • DH1, limebuzz and IamSherwood have said thanks
#17 KennyP ONLINE
  • 51034 Thanks
  • 52658 posts
Posted January 31, 2015 - 06:50 AM
Now I'm dizzy!
#18 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted February 08, 2015 - 02:14 PM
I received some cable and crimps from "Iamsherwood" and finally got them installed on my snow thrower.
Easy to do and now it works. :dancingbanana:  :dancingbanana: :dancingbanana:
  • limebuzz, IamSherwood and KennyP have said thanks
