Need Help with Jake Tiller Lube
12 replies to this topic
#1 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted January 25, 2015 - 04:55 PM
Another thread reminded me to see if someone can tell me what lube from today will sub for what Jacobsen called out for in their tiller manual.
I have tried Googling and no help unless I missed something.
  • Bolens800uk said thank you
#2 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted January 25, 2015 - 05:10 PM
this is what google shows me    https://www.google.c...exaco marfak 00
#3 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted January 25, 2015 - 05:25 PM
That tells what it is, but what can you use instead of it? That's what I am looking for!
  • tinbender7 said thank you
#4 drbish OFFLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted January 25, 2015 - 05:53 PM
I found this discussion on a good replacement
http://www.practical...bricant-256785/
#5 Alc OFFLINE
  • 7,129 Thanks
  • 7,532 posts
Posted January 25, 2015 - 06:11 PM
I found this from tinbender7 link ,, I bookmarked it myself
http://www.machinery...sed-gear-drives
#6 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted January 25, 2015 - 06:42 PM
I guess they are saying the Mobilegrease XHP 220 is what to use. The tiller gearbox has needle bearings, straight cut gears, and a chain in there. I just don't want to add something the is not compatible with the factory lube and blow out the gearbox.
#7 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted January 25, 2015 - 06:56 PM
general purpose lithium is all i can come up with.
#8 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted January 26, 2015 - 05:13 AM
One of the lubes in the Jake manual says Mobil 00 or equivalent.  Snapper uses 00 grease it is thicker than gear oil thinner than wheel bearing grease.  Snapper has 2 gear boxes, one is a chain case, one has straight cut gears and needle bearings, probably similar to a tiller gear box.  afaik snapper 00 is used on all the machines back to the 60s.   Old jake tillers probably had similar grease technology to what Snapper was using back in the day as far as "base stock" or whatever the term is, so i'd guess they'd probably be compatible as far as chemicals.  Stens makes Snapper stuff here is a link good luck http://www.ebay.com/...=item3a8516f0a4
#9 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted January 26, 2015 - 06:27 AM
Thank you. I'll probably get that if it is needed. Both the tillers show signs of seepage, so I'm thinking they might need topping off.
#10 Alc OFFLINE
  • 7,129 Thanks
  • 7,532 posts
Posted January 26, 2015 - 06:32 AM
I was thinking how my Grandfather on his Sears Custom 6 he would mix wheel bearing grease and gear lube  for mower deck gear boxes because they would leak with just the gear lube which was called for . There is probably a lube that would have done the same thing .
#11 OldBuzzard OFFLINE
OldBuzzard
  • 7,082 Thanks
  • 4,809 posts
Posted January 26, 2015 - 09:09 AM
#0 and #00 are also known as "Corn Head Oil"
You can find it at an AG dealer like Case-HI or Deere.
  • limebuzz, KennyP and donjdlx have said thanks
#12 Bolens 1000 OFFLINE
  • 15,298 Thanks
  • 18,236 posts
Posted January 26, 2015 - 09:24 AM
Yes, I believe thats what is recommeded for this application, same as most snow thrower gear boxes
If you guys cant find It locally I sell bottles of this 00 Grease :thumbs:
#13 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted January 26, 2015 - 10:15 AM
I'm not sure if I even need any as yet, but wanted to know what to use before hand. Thanks everyone!
